Old 06-08-2011, 07:58 AM   #1
Unhappy Welder issues
ok i got older welder 110v I weld sometimes and works great other times it goes and then just stops nothing... will not feed the wire at all i pull the wire out more and not hung up just not feed or getting a spark went i hit the steel... put it way for a few days bring back up and works again...
really strang, and one know what is going on here or what i should check out when this happens?
Old 06-08-2011, 09:53 AM   #2
fmlewis
The best damn Engineer!!!
I got el cheapo Harbor Frieght welder. What I have found with mine is that you need to make sure the line leading to the gun isn't twisted or has tight bends in it, otherwise it feeds great.
Also, you wire size may not be the right diameter for the feed mechanism, but I would expect you to have problems all the time.
Old 06-08-2011, 10:07 AM   #3
jfiscus
jfiscus's Avatar
Pull the trigger with the cover open if it has a cover. See if the feed wheels are turning & in-turn feeding the wire through them. If the wire's feeding fine there then I would assume the liner needs replaced.
Old 06-08-2011, 12:40 PM   #4
you might just be hitting it's duty cycle, and after it cools down it starts working again...
Old 06-08-2011, 01:11 PM   #5
Yeah, if it works and then stops, it's either the electronics are messed up or hitting the duty cycle. It depends on how long you are using it before it stops feeding.
Old 06-08-2011, 01:24 PM   #6
oklahomawelder
Tradin' Fool
THIS^^^^^ would be my bet.....
Old 06-08-2011, 03:24 PM   #7
yea those little welders don't have much of a duty cycle if i remember right.. It should tell ya about it in the manual if you still have it laying around...
