09-11-2011, 01:36 AM | #1 |
Uneven Rubicon Express leaf springs
After six months and a couple thousand miles, my second-hand but never-before-installed RE 3.5" springs have settled very unevenly.
I'm measuring about 3" lift from the passenger spring, and 4" from the drivers. 1" difference there makes about 1.75" difference at the bumper ends, producing a gangsta lean you can see from across the street. Friends, coworkers, even strangers are starting to hassle me about it. Yes, I have loosened and retightened the bushing bolts more than once. Yes, I'm sure its the leaves doing it. Yes, I verified that they're both stenciled "RE 1463." Although, the stencils themselves are completely different: 4" drivers: 3" passenger: Don't know, probably doesn't mean anything... So anyway, what are my options? Here are my non-options: - I can't hassle RE about them, I bought em second hand. Unused, but second hand. - I'm not spending $400 on new springs and throwing these "premium" leaves in the trash. - I can't buy one new one, because (a) it'd be a crap shoot which side to put it on, and (b) these started at about 6" lift. Replacing just one would make it lean so bad it'd drive funny. I guess I could pull a leaf out of the tall one, or add 1" block to the short one. I actually have an overload spring I could use. It's pretty well flat, but 1/2" thick. I could do that and a 1/2" block. Thoughts? Robert
09-11-2011, 04:14 AM | #2 |
COMANCHE NUT
you could take them off separate the leaves compare and maybe mix leafs between the packs to get them to match height ? just a thought
09-12-2011, 12:57 AM | #4 |
They call me......Scuba
sounds about like the best option IMO. take them off and see how they compare without a load on them.
beat up rusted out k5 |
09-13-2011, 01:13 AM | #5 | ||
Tom, you've got a pm incoming... Robert
09-13-2011, 09:00 PM | #6 |
COMANCHE NUT
I can bring you couple jack stands no problem
09-16-2011, 01:42 PM | #7 |
Xj Mj bastard pack
09-11-2011, 10:32 AM | #8 |
Start parking it overnight flexed up on something. May compress the higher side over time...?
my next rig will be on the trail before zuk 2.0 will |
