Old 11-15-2011, 04:50 PM   #1
tjrider
tj tcase drop removal
After a somewhat discouraging run at haspin last weekend, I've realized what I need to work on. My question is, can I take off my tcase drop without lengthening my drive shaft? I have a sye and cv shaft already. Just don't know if it would pull the slip yoke out too much. Its only a 1" drop
Old 11-15-2011, 06:52 PM   #2
You should be fine but nobody can say for sure without looking at it in person. As you raise the transfercase backup you chouls also adjust your pinion angle accordingly which will minimize then amount your driveshaft lengthens. One of my favorite mods was putting a "tummy tuck" skid on my TJ.
Old 11-15-2011, 07:10 PM   #3
tjrider
i just put spring pirches in, so im not cutting and adjusting. the cv drive shaft should handle the angle. i just dont know how much more it will the the shaft out.
Old 11-15-2011, 08:02 PM   #4
T-bird
T-bird's Avatar
If you have a SYE there is no reason to have a transfer case drop. If you remove it, you will most likely have to adjust your upper control arms so that your pinion points at the transfer case. It will be pointing a little low and you will have to lengthen them.
Old 11-15-2011, 08:37 PM   #5
tjrider
I put the lift on years ago before I knew any better, my control arms are factory non adjustable. I don't think I have that much adjustment. The drop came in the kit. It is a superlift short arm kit. Would I need to get adjustable arms first?
Old 11-15-2011, 09:19 PM   #6
tjrider
What if I pull the Tcase drop and add a 1" MM lift? Those are a lot cheaper that adjustable arms and you get new motor mounts...... Just a thought. They're supposed to help issues like this
