Old 02-13-2012, 05:49 PM   #1
tjrider
tj electric fan setup
I know a lot of you guys are running these, but I want to convert to an electric fan set up on the tj. I know I can piece something together cheaper than buying a "kit". But I don't know what all I need to make this happen. What switches and such do I need and what kind of fan should I run. I do have a 180 thermostat in now. Thanks guys
Old 02-16-2012, 09:06 PM   #2
superjeep
Are you having it come on at a certian temp or off of a switch. I have mine on a switch so I can shut it off in deep water. my distributer is low on the engine. their is a bunch of ways to do it jegs has some good prices. If you get a bad fan (used junk yard fan) that works at first and goes out while you are out you are screwed. I had to find a junkyard and get a manual fan to throw back on the jeep to make it back to cincinnati after my electric fan locked up.
Shawn
Old 02-16-2012, 09:14 PM   #3
underpowered
They call me......Scuba
the ford taurus 3.8l fan is very popular for this kinda swap. they are 2 speed and have a very high CFM rating.
beat up rusted out k5
Old 02-17-2012, 07:34 AM   #4
tjrider
I've been reading a lot about the taurus swap. I don't like deep water so probably no switch. I didn't know if anyone had used a fan from any local parts stores
Old 02-17-2012, 07:59 AM   #5
Almost any fan is great, as long as there is a proper shroud. The taurus fan is the whippety **** for sure, especially if you pick up the offroad aftermarket switch/relay system.
But again, almost any fan, if shrouded correctly is good to go.
Old 02-17-2012, 08:09 AM   #6
Trigger
I ran one out of Crown Vic that worked pretty well. Never had an issue with overheating.
Old 02-17-2012, 08:27 AM   #7
X2 on the shroud... I have seen quite a few electric fan setups still let motor over heat because shroud wasn't up to par... It took me a while to realize thats why one o mine was overheating
Old 07-09-2012, 08:50 AM   #8
How thick is this fan? I would like to see if it will fit between my radiator and engine.
Old 07-09-2012, 12:36 PM   #9
tjrider
I can measure it tonight, but I'd say @ 3" with motor. Not positive
Old 07-09-2012, 09:49 PM   #10
tjrider
My tj only had @4" between the block and radiator. You can trim some of the shroud as ling as it still fits your radiator. They are pretty slim though
Old 07-09-2012, 11:09 PM   #11
I may go this route then instead of changing the oil in my fan clutch. What application did you end up sourcing from?
Old 07-10-2012, 07:13 AM   #12
tjrider
95 Taurus with the 3.8 motor. Single 3 wire fan
