Go Back   C.O.R.E. FORUM > Support and Testing > Get Help
Old 09-02-2007, 10:21 PM   #1
Stang849
Stinkin Bastige
Stang849's Avatar
Images: 236
Couple of questions
Question 1
On other forums I'm on I don't have to hit a button before using the quick post reply box. Is this just a setting on the server? I know its just minor thing but kind of annoying, its called a quick reply box for a reason.
Question 2
I tried to post thumbnails of some photos from the gorge off of photobucket and they didn't work. They worked fine when doing the pictures themselves, just not the thumbnails. Any ideas???
Old 09-03-2007, 02:13 PM   #2
at this point you have to use the quick reply button to make a quick reply. it's a code modification i havent figured out yet... but really, is it that difficult? I will work on it for you.
not sure why the thumbnail thing isn't working for you, i have seen others use it with no problem... I don't have a photobucket account so i can't test it for you.
maybe you could try to do it again in this thread and we can troubleshoot it together.
Old 09-03-2007, 04:25 PM   #3
Stang849
Stinkin Bastige
Stang849's Avatar
Images: 236
No its not that difficult to hit the quick reply button, just annoying ;)
Here is what I get if i try the thumbnail option on photobucket.
<center>
<a href="http://i156.photobucket.com/albums/t5/Stang849/DSC_1297Small.jpg" target="_blank">
<img src="http://i156.photobucket.com/albums/t5/Stang849/th_DSC_1297Small.jpg"></a>
<a href="http://i156.photobucket.com/albums/t5/Stang849/DSC_1293Small.jpg" target="_blank">
<img src="http://i156.photobucket.com/albums/t5/Stang849/th_DSC_1293Small.jpg"></a>
</center>
if need be I'll give you my screen name and password to photobucket if you need it to figure it out.
Thanks
Old 09-03-2007, 10:41 PM   #4
ok, i figured out how i can make the click not required for the quick reply. But, there is one advantage to the hitting of the button.
If i am making a quick reply to a post in the midst of 10 other replies, i can click the Quick Reply button and then hit the "quote message in reply" check box, and it will quote that message in your quick reply.
That can be an advantage, i guess. So, it's possible to turn off the need to click the Quick Reply button, but i would like to hear some other's opinions on it before i made a change like that.
Still working on your code issues....
Old 09-04-2007, 10:02 AM   #5
Ok, here it is... but you have to catch me on IM or something for me to give you the code to do it, cuz if i give it to you here... it will just show the images again... or look below, i will try to replace things...
the code is much simpler than your code... below, the curly braces " { } " should be replaced with square braces " [ ] " Get it?
{URL="http://i156.photobucket.com/albums/t5/Stang849/DSC_1293Small.jpg"}{IMG}http://i156.photobucket.com/albums/t5/Stang849/th_DSC_1293Small.jpg{/IMG}{/URL}
{URL="http://i156.photobucket.com/albums/t5/Stang849/DSC_1297Small.jpg"}{IMG}http://i156.photobucket.com/albums/t5/Stang849/th_DSC_1297Small.jpg{/IMG}{/URL}
But honeslty, if you want to, you can just link to the fullsize images in the thread instead of thumbnailing them all... no need really.
Old 09-04-2007, 10:06 AM   #6
If you have any more problems you can borrow a 1/4 stick from me and a lighter!
