Old 03-17-2012, 11:22 AM   #1
85jeepn
Dana 60 builder parts
Time to face reality my work hours aren’t going down and my energy level isn’t going up and I am never going to get back to this project so It’s time to sell it off to fund other hobbies.
Everything is PLUS shipping unless other wise stated.
Everything is NEW unless other wise stated
-Rock Crusher D60 high pinion center section $650.00 SOLD
-Ruff Stuff D60 Diff cover welds smoothed and $90.00 shipped SOLD
POR 15 Black $80 if picked up
-D60 Detroit locker 35 spline $550.00 SOLD
-Dedenbear (Reid racing) D60 inner “C’s” $350.00 SOLD
-Solid Axle Industries High steer king pin knuckles w/ $500.00 SOLD
Custom high steer arms springless design
-Solid Axle Industries 35 spline drive flanges $175.00 SOLD
-Warm Premium 35 spline lockout hubs $200.00
-CTM D60 ujoints $550.00 SOLD
-D60 35 spline stub shafts 4340 chromoly w/ $300.00
Seal kit
-D60 inner shaft short side chevy chromoly $150.00
-D60 spindles 6 bolt chevy w/ nuts and washers $200.00 SOLD
-Stock used Chevy D60 caliper brakets very good $85.00
shape sand blasted and primed
-King pin kits lower bearing and seal, upper bushing, $75.00 SOLD
King pins and springs
-D60 Timken wheel bearings races and grease seals $50.00 shipped SOLD
-D60 custom made lower king pins $120.00SOLD
Never brake off bolts or grease zerk again
-D60 used dually hubs blasted and painted with $125.00
POR 15 w/ New rotors
-D60 bare housing long side tube cut off at knuckle $200.00
tube cleaned out of knuckle ready to be built to your
length Chevy stock
-D60 Stock brake calipers and pads NEW $65.00 SOLD
Located in Covington OH 45318
Email me at jjswabb@gmail.com
Name:	d60 HOUSING.jpg
ID:	5058   Click image for larger version
ID:	5059   Click image for larger version
Name:	diff cover.jpg
ID:	5060   Click image for larger version
Name:	Drive flanges.jpg
ID:	5061   Click image for larger version
Name:	hy steer arms.jpg
Win at all cost. Second place is just the first loser. www.buckeyejeepers.com
85jeepn is offline   Reply With Quote
Old 03-17-2012, 11:24 AM   #2
85jeepn
More pics
ID:	5063   Click image for larger version
ID:	5064   Click image for larger version
Name:	lower king pins 2.jpg
ID:	5065   Click image for larger version
Name:	lower king pins.jpg
ID:	5066   Click image for larger version
Name:	Inner shaft.jpg
Old 03-17-2012, 11:26 AM   #3
85jeepn
more pics
ID:	5068   Click image for larger version
Name:	stub shafts.jpg
ID:	5069   Click image for larger version
ID:	5070   Click image for larger version
Name:	Hub Rotor.jpg
Old 03-20-2012, 08:20 AM   #4
johnb1686
johnb1686's Avatar
You don't happen to know if those knuckles will work on a ford axel? Or have apart number for them
johnb1686 is offline   Reply With Quote
Old 03-20-2012, 06:25 PM   #5
85jeepn
They will only work if you convert to Chevy or Dodge parts all the way out. These have the 6 bolt pattern to work with Chevy spindles Ford uses 5 bolt pattern on knuckle.
Old 03-21-2012, 08:43 PM   #6
85jeepn
Post updated
I am coming down to Cincy this Sunday afternoon if anyone is interested in anything. Makes for FREE shipping and not alot of wasted gas for you.
