Old 04-26-2012, 01:36 PM   #1
jlynch
39.5 Iroc radials
Anybody ever run these? I can get a set for a great price. Just looking for opinions on the iroc's in general.
thanks
Old 04-26-2012, 01:52 PM   #2
frankensteinxj
frankensteinxj's Avatar
What are they going on?
From what I have heard they are great with a lot of tread and they are ok once they are worn down a little.
I've wheeled with guys that run them and they seemed to work well.
BYAAH!!!
Old 04-26-2012, 02:02 PM   #3
jlynch
They are going on a jeep with one tons. It is used for off-road only.
Old 04-26-2012, 02:05 PM   #4
Trigger
They aren't the best tire for this area. I ran them on my old YJ and they don't do well in mud, etc. That said, if they're cheap, I'd go for it. They're not so bad that I would pass up a good deal on them.
Old 04-26-2012, 02:10 PM
Old 04-26-2012, 02:22 PM   #6
jlynch
Originally Posted by stickman View Post
Did you mean to say iroks bias? Cause if yur talking radial then there's only one to get, and that ain't it...
They are radials and its $400 for four of them 90% tread, one has a sidewall cut that will need repaired.
Old 04-26-2012, 09:22 PM   #7
nick
wheeler
Never had radials but run the bias for close to three years I won't buy another set. Unless I got a killer deal yours don't sound bad if they r a decent size tire. IMO they look wore out when u get them and wear quick. Also the side walls r thin I run bead locks and can't go less than 10# of air pressure. But they go pretty good never had goin issues just flat tire from blowin inner bead
Casey built cj7, amc 360 fuel injected, 39.5 Irocs,14 bolt+60 detroits, 4 linked front and rear, 203/205 doubler etc...........
nick is offline   Reply With Quote
