2k XJ
Selling my XJ.
Modifications (the Goods) - Remote Start Sony Explode CD Player w/ remote and detachable face plate Amp and Sub woofers (currently disconnected) Swapped in High Pinion Dana 30 4:56 gears Ected Electric Locker in the front Detroit Truetrac In rear Chrysler 8.25 Slip Yoke Eliminator (SYE) Tom Woods rear Driveshaft 6.5 Rough Country Lift w/ Long Arm conversion Rough Country Shocks in Front Rough Country Tubular Rock Sliders Bilstein 5100’s in the rear. 35x12.50 R15 BF Goodrich KM Mud Terrains (including Full Size spare) ATX Teflon coated Chamber wheels JCR Stage 3 Front off road bumper with winch mount Hella 500FF Auxiliary Lights Uniden CB w/ Firestick Antenna Jasper replacement Motor Performed at 97,870 Miles (currently 101,192 on the clock, so engine is basically brand new) Also just performed Oil change Replaced Battery New serpentine belt New Alternator New Front Brake Pads, Rotors, and calipers New Oil Pressure Sending Unit Bad – This has primarily been used as a dedicated wheeler for the last two years, so the paint does have scratches (Kentucky Pin striping). One of the Hella Aux lights has a broken lens. Driver rear tire has a slow bead leak. Since it has been sitting, the tires could use a re-balancing. AC needs to be recharged. Additional – I have owned the Jeep since 2004. It has always received regular maintenance. The replacement engine was to address the 2000’s cylinder head design flaw, and was replaced with the corrected appropriate head (similar design to the ’99). Since we have owned it the jeep has always been tagged and plated in Kentucky. It is completely road safe. Buyer will also receive a 48’ Farm Jack and set of tire deflators. The jeep is far from perfect with minor scratches, dings, and small dents, but it has seen many local trails and has always made it home. It is as solid as an anvil and just as tough, just needs someone to use it. askin $5500 price is firm, Too many new parts to go lower. ![]() ![]()
![]() Last edited by xxj; 05-06-2012 at 09:02 PM. Reason: Forgot to add price |
Bump for price drop -
now $5000
If anyone is thinking about it this Jeep has alot of nice parts on it and goes well. I took it through Mason Jar in Harlan last fall with no issues.
Ian 06 Toyota 4Runner |
did you go the bypass route or actually go up the ledges?
Bypassed most of the ledges. Scott (XXJ) wasn't there to give me his blessing and I wanted to bring it back to him intact.;)
Interested in any trades?
BYAAH!!! |
Might be interrested in a solid commuter car....
gotta battle these gas prices :)
I can just about guarantee that it's just crap caught in the bead. The KM's have that little "rim protector" lip, and I was always having trouble with them pulling bark, dirt, whatever down inside the bead.
I/you could pull the wheel off the jeep, use the hilift to pop the bead, clean the crud out, and have it aired back up and back on the jeep in about a half hour.. Minor hassle, sure, but I bet there's nothing really wrong with the tire... Good luck with the sale, it is a nice rig! ![]() Robert
Bump for the weekend
