setting backlash
ive been looking around for a good thread that goes in depth about setting backlash. i will be building my axles here soon this is my shy area. in case it matters i will be doin it on a HP30 and an 8.8
bryan
im good on the tolerance its more of the how to. ill be switching ring and pinion to run 4.88 well pretty much a complete rebuild. so a "how to set backlast correctly for dummies":confused: is what im lookig for.
- Administrator - |
Well, the placement of the shims differs with some axles. I have found that starting with the original shims gets you close. It can be a pain to get your correct backlash and a good tooth pattern. You'll need a dial indicator and a micrometer. Some of the shims are behind the side bearings, which need a puller or press to remove. I've read many how to articles online about it. I've done it about 7 times. I say read up a lot and dig in. Reading the tooth pattern tells you what it needs.
#5 | |
by the time all this goes together i will be out of the military (june this year) so might hav eto have a garage party with someone who can teach. id like to do it right the first time.
#6 | |
One of these days Zuk 2.0 |
