Old 05-30-2012, 08:37 PM   #1
90YJ
thinking of buying tube bender
i am interested in purchasing a new or used tube bender.any recomendations on one that is good but reasonablely priced?
thanks
90YJ is offline   Reply With Quote
Old 05-30-2012, 09:06 PM   #2
I bought the JD2 Model 32 manual bender. Price wasn't too hateful.
Old 05-30-2012, 09:51 PM   #3
GCJEEPING
GCJEEPING's Avatar
X2
01 Grand, 6in lift, 33's, Aussie locked 30/35, front disco's, home made rock rails, Surco rack, grille guard, front and rear hitch, t-max 12500lb hitch winch, rock lights, Mean geen alt, TJ transfer skid plate, OBA and a few other things.
GCJEEPING is offline   Reply With Quote
Old 05-30-2012, 11:06 PM   #4
kentuckytwostep
corsets make it tighter
kentuckytwostep's Avatar
JD2 here too. Kind of the benchmark I guess.
my rig
Old 05-30-2012, 11:18 PM   #5
I have a jd2 model 3... Works good but if I had to do it again I would have bought model 32 or model 4... The model 3 is great if your bending 1.5 x.12 all the time but 1.75x.12 really gives it a workout.. I had to beef up the mounts...
Old 05-30-2012, 11:36 PM   #6
I started out with a model 3 for my first bender. It's the predecessor to the Model 32. We use a Model 4 at the shop, and now I can't imagine using anything less. The way they work is different as well. For small home shop projects, the 32 will do you just fine. The suckiest part about a manual bender is that it has to be mounted to the floor and limits what you can do with what kind of space you have.
Old 05-31-2012, 12:52 PM   #7
get the 3/32....it be great for what u need it for. the 4 just operates differently than those, in the way the die and the followers actually form the tube. on the 3/32 the tube clamps to the die and the followers do the bending. 4 is opposite...
32 is rated for thicker wall tube than 3 or 4 as was mentioned.;)
other than what was mentioned, spend some $ for a digital angle finder, digitall torpedo, and a tube clamp.tube bandit is good but i think out of buissness now. take care of ur dies, doont run rusty tube in them, don't let them rust. and only buy the 180 degree dies... not the 90s.....
do the math and the calibration exersizes, note that your springback changes after u get above 95 or 100 degrees.
that's all I got to add...
I'm lookin forward to see your tube work!
Sent from my LS670 using Tapatalk 2
Old 05-31-2012, 02:06 PM   #8
Nuts's Avatar
The model 32 is built stronger than the 3 & 4. I know a guy that has a 4 and he borrowed my die from the 32, and everything about the 32 was bigger so he couldn't use it. You can spend the extra $400+ and get the hydraulics for the 32. The new one that's replacing the model 4 is going to be top notch. The biggest I've bent with mine is 2 1/8 x .188 DOM. It's a workout bending that manually.
Have you seen a 32 and a 4 side by side? The 4 is much beefier. Dies from the 32 won't work in a 4 anyway, unless you buy and extra shoe for them. And model 4 dies won't work at all in a model 32, as they don't have the extra leg coming off of them.
You guys know alot about bending! I just slide some tube in and hope it comes out how I want it
KYrel69 or whatever his screen name is has a pro tool 105 he might sell ya
Old 06-05-2012, 10:57 PM   #9
kentuckytwostep
me too...
my rig
Old 06-07-2012, 02:10 PM   #10
I just saw this and thought it might be worth a look...
http://forum.ih8mud.com/vendor-marke...e-die-set.html
Old 06-07-2012, 02:37 PM   #11
nickhuts
GRAB A SNATCH BLOCK!!
nickhuts's Avatar
Looks like it does the job..too pricey for me though...
Old 05-31-2012, 02:11 PM   #12
that's cause ur just that awesome....heck, I bet u even make ur own knuckles dontcha?
Old 05-31-2012, 04:06 PM   #13
90YJ
thanks for all the great advice it is all very helpfull
Old 06-01-2012, 04:09 PM   #14
Nuts's Avatar
Old 06-05-2012, 09:12 PM   #15
nickhuts
nickhuts's Avatar
I am in the market for one also...the price on that 105 looks good. Any used ones floating around? It does not matter which bender. I need to bend 1.5in .120 wall...
