Old 06-04-2012, 09:46 AM   #1
tjrider
ford 44s
I have the chance to buy a front Ford d44 for cheap. Its from a 79ish f150, and I believe its the radius arm setup. Will this work for a tj? I've read somewhere that certain models wont fit. I think they had cast knuckles....? Need some input before I lose the deal
Old 06-04-2012, 12:05 PM   #2
frankensteinxj
frankensteinxj's Avatar
The cast knuckles limit you to using only ford radius arms unless you completely retube the axle.
I learned the hard way when I bought one for my xj. Ended up at the scrap yard.
If I were you I'd wait for a different deal.
Ford 44s arent to hard to find.
BYAAH!!!
Old 06-04-2012, 12:08 PM   #3
tjrider
Would it be stupid to run Ford arms? I saw it in a mj once
Old 06-04-2012, 01:00 PM   #4
frankensteinxj
Ive seen people run them and have no problems with it.
It just limits it to only being able to use the radius arms.
Here is a good thread about with a guy using them in tj.
http://www.pirate4x4.com/forum/showthread.php?t=791009
BYAAH!!!
Old 06-04-2012, 04:50 PM   #5
tjrider
What does it mean to "wrist" one of the arms? Heims? That setup doesn't look too shabby
Old 06-04-2012, 10:55 PM   #6
kentuckytwostep
corsets make it tighter
kentuckytwostep's Avatar
I ran a setup pretty much like his in my XJ... flexed like a pro without wristing either arm. My only advice is if you are going to run a 44 with 35's or larger tires, splurge for GOOD axle joints.
my rig
