06-08-2012, 01:31 AM | #1 |
tj marker light question
so heres the problem im having. the running lights on the front of the tj arent working but the turns do. the rear running lights and turn work fine its just both of the front. tested the wirering and its all good for both running lights and marker lights, could it just be both front plugs need replaced.any ideas.
06-08-2012, 02:47 AM | #2 |
Bulbs?
06-08-2012, 05:07 AM | #3 |
put new bulbs in when i did the tj conversion, the problem was there before the conversion and yes they are dual filament bulbs.
06-08-2012, 08:50 AM | #4 |
I have had to replace the sockets on a few TJ's. It's wouldn't surprise me if the sockets are bad. They tend to hold a lot of crud.
06-08-2012, 06:48 PM | #5 |
i noticed that when i had the bulbs out. i just didnt see both front sockets going bad at once. or atleast notice it at once. any idea where the best place to order a set from.
06-08-2012, 08:24 PM | #6 | |
