XJ Parts
Parts off an 88 XJ
Front Dana 30 HP with 3.56 gears, knuckles drilled for 5/8" hiems and track bar setup for 5/8" bolt hiems. - $75 Homebrewed rock rails, they were originally welded to the uni-body. Either add feet to bolt the rails or weld it to the uni-body stiffeners. Made of 2" X 2" X 1/4" steel - $50 The start to an on-board welder - an alternator of a Crown Vic ( High amp 85ish?), mounting brackets to run a 5V belt off the power steering pump on an XJ, little electrical control box with 110 oultet to run brushed motor pieces of equipment while on the trail and some wire to make the connections for the true welding leads. -$75 ADDITIONAL PARTS 2 steering boxes one with stock pitman arm - $30 each stock rear shaft from Aw4, 4x4 -$30 Stock alternator - $40 Intake manifold with all sensors and TB still on $40 I am getting out of the Jeep scene for a little bit, too many hobbies at the moment and this one would take me a bunch of time to get going. Make me an offer on everything and I can make a pretty good deal. All of it for $150, minus the OBA and OBW setups. $250 with those.
88 XJ - 5" lift - 35" BFG's - Bumpers - Rock Rails - Homebrewed OBA - Roof Rack - Tube Doors - Trimmed - Dented 87 XJ - D44 - Disco D30 - 235's - 231TC - Stock for now Last edited by RuffedUpXJ; 06-18-2012 at 08:34 PM. |
Interested in the OBA. Is it a stock a/c compressor? You don't list an oiler or filter/seperator, did you not need one?
Thanks! Robert
#3 | |
There was a kit that had that stuff and some quick disconnects I used. Ran great and with just a switch it's automatic. Plus there is a guage and pressure relief valve and wiring is simple. http://www.cincyoffroad.com/forum/sh...23&postcount=6 There might be something on Jeepforum about it, I know there was something on Terrain Stompers but I think it's gone.
I have a buddy who.is looking for a hp30 I will pass him this amd let you know
Sounds good let me know, someone came and checked it out last night but they won't have the money for a week or so. Let me know.
OBO on everything.
#6 | |
Would be nice to have... Robert
