Old 07-16-2012, 05:02 PM   #1
T-bird
T-bird's Avatar
Tire Groover
I am thinking about cutting the lugs on my LTB's because I don't think my tires contour to the rocks as well as they could under my light TJ. Does anyone have a tire groover or an easy way to cut the lugs?
Old 07-16-2012, 05:25 PM   #2
rilynsdad
rilynsdad's Avatar
I used a 1 1/4 wood chisel and a map-gas torch and heated up the chisel's tip to cut the small lugs on my bogger's it work pretty fast two tires in a hour not bad, it cut through like butter... I check out youtube first.
HOLD MY BEER!
Old 07-16-2012, 06:50 PM   #3
This ^^
Doing it this way is 10x faster than messing with a Ideal type groover..
Old 07-17-2012, 07:56 AM   #4
I'm sure the 1 1/4" wood chisel would be faster for cutting out the small lugs of a Bogger, but for cutting a 1/4 - 1/2" groove across a tread block the groover should be faster. Exact same concept with the exception you don't have to stop and heat up the blade with the torch. I cut a 1/2" groove through the middle of each tread block on my 39.5" TSL's in about 15-20 minutes per tire.
Old 07-17-2012, 09:07 AM   #5
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
Don't b a girl, use a chainsaw........faster than any grover out their. If you have a small battery powered or electric saw its one handed and effortless.
Old 07-17-2012, 10:33 AM   #6
T-bird
T-bird's Avatar
I was looking at something more like this
and not removing an entire lug.
Old 07-17-2012, 07:14 PM   #7
u&k metal works
u&k metal works's Avatar
He's right
