Old 09-28-2012, 11:20 PM   #1
Eletrical Gremlin on my bike
Electrical Gremlin - I have gone round and round with my battery going dead on my 99 honda shadow ace tourer. I have replaced it with a new battery and have put it on a battery tender which i bought new also.. Light will go from red to green after a few hours so I believe that it is charging it..If you take it off and try to start it and it just clicks and not enough to start the bike. The bike has sat on the tender for about 3 weeks..
Something to add to the mix..I am running power to garage on 15 gauge extention cord and then put on a 6 outlet power strip which had a ground fault light which is lit.
older house with only 2 prong outlets in the house..
If I put the battery on a jump box charger it will charge it up also or if jump it with my truck it will start.
where should I start????:confused:
Old 09-29-2012, 08:23 AM   #2
Sounds to me like you are trying to burn your house and garage down....
LIKE IT OR LEAVE IT!!!
Old 09-29-2012, 10:04 AM   #3
timido
Student Driver
timido's Avatar
Jump start the bike and check battery voltage with it running. If it is charging probably 14 volts then your battery is bad or you have a draw on the bike that is killing the battery
Old 09-30-2012, 06:21 AM   #4
it is 13 -14 volts when running but when the bike sits a while( few days) it drains the battery ( 10 volts ).. even if it is on the battery tender..:confused:
it a new battery, old battery was doing the same thing and got a replacement so this is battery # 3....
Old 09-30-2012, 11:20 AM   #5
I think u answered your own issue here... U have a draw somewhere pullin your battery down and it sounds like charger doesn't have enough ass to come the draw with the ****ty extension cord... Take the battery out and charge it in house overnight direct from a plug in the house... See if it starts bike... If it doesn't u may have a starter issue... It could be the draw and the problem.. (I'm just thinking outside the box here) when u jump it from truck doesn't that provide a lot more cranking amps than a motorcycle battery? So if u have a weak starter with an internal problem maybe the big truck battery can overcome the starter but the motorcycle battery can't?? Follow?... Again suggestion
Old 09-30-2012, 03:26 PM   #6
flatlander757
Fartface extrordinair
To find a parasitic draw, check out this post I made detailing how to do it:
http://www.pirate4x4.com/forum/elect...l#post14605491
Before you do any testing with a DVOM though, charge the battery up fully, and leave it disconnected and let it sit for a day or two, and make sure it still has voltage... if not then your battery is dead again and if you try testing for current drain with it you'll possibly get some bad readings.
Old 09-30-2012, 06:24 AM   #7
lol well a i do need to run electric to the garage ( wire need to be 80 foot )but that can be price to get 220v out there to run a welder and air compress power tools and charge all my batteries and such...plus only have 100 amp service coming into to house...build in 1954..
Old 10-05-2012, 02:49 AM   #8
Well I tried the test light on the neg post and wire. no light.
then took off the neg wire and clip it to the wire and touch neg post no light... so i dont think i have a draw there..
i did charge it up ( so i thought) meter said 13.1 , turned the key over and it tried to started. then I tried it again and then it it just clicked... put the meter back on it and it said 9.4...:confused:
So i took out the battery to the house and charging it up there. Battery there says 13.1 again. took it off charge and going to let it sit over night to see what the charge reading is in the morning...
the drama continues...
Old 10-06-2012, 09:37 AM   #9
After letting it sit, it went down to 12.7 then I let it sit another day and it went down to 12.6 . This is off the bike and in my house..
So do I have a bad battery or is this drop normal?
Old 10-06-2012, 05:26 PM   #10
timido
Student Driver
timido's Avatar
Take it to an auto parts store that has a battery load tester.
Old 10-07-2012, 01:44 AM   #11
try that and see... if they can test a mc battery most auto stores just looka at u and go uhhh idk..
Old 10-07-2012, 09:09 PM   #12
Nuts's Avatar
Strip all the electrical bs off it and start kicking it like a man!
Old 10-07-2012, 09:23 PM   #13
But not auto zone....lol....i took a battery there years ago and they said yup its bad" and i bought a new one and two days later they had my "BAD" battery for sale in the used battery section...bunch of theives....
