I beat anorexia!
wheel adapters?
whats everyones opinion on wheel adapters? I am thinking about buying a new rear axle and it is 5 on 5.5. all my wheels are 5 on 4.5. just wondering if it is worth it
I believe this will be our finest hour |
they are safe, i used to use wheel spacers, 4" ones in fact, on the back of my last jeep...
problem is the adapters will make you wider just like a spacer, by at least an inch or so each side.
I beat anorexia!
that isn't bad in my book, I want to be a little wider anyway. Do you sell adapters mike?
You can get them at www.aimind.com
Just make sure you re-torque them after an initial 100 miles or so. Then check them every so often afterwards. Aluminum will expand and contract and loosen up the lug nuts, and since you will have 10 per wheel now it will be important. |
I beat anorexia!
I almost think for that price I will get the Super 88 kit for it. I was looking at this site just for ideas... google
http://www.ezaccessory.com/Wheel_Ada.../5550-5450.htm
I beat anorexia!
http://www.jegs.com/webapp/wcs/store...0002_192370_-1
this one looks pretty dang cheep though http://www.jegs.com/webapp/wcs/store...0002_804698_-1 that one isnt bad
I have welded up the holes before and put a new bolt pattern in the axle shaft before but would not be comfortable doing that on a daily driver. I have wheel spacers on the truggy. 3.5'' in the front and 2'' in the rear and run them on the mustang too! Be sure to recheck the torque and use locktite.
