Stinkin Bastige
Newbie Front Axle question
My wife (tjjeepjeep) and I are looking at starting to build her TJ for more serious offroading/rock crawling. Would a Ford F350 Dana 50 front axle be a good swap, or would it be better to just get a Dana 60? Thanks for the help.
Your wifes pimp!
What rear axle are you thinking and how big are you talking? tire size 35's, 37's, 40's
The D50 is not a bad axle just not enough support and you would be limited in your swap. and the cost would not be worth it. 37's or under build a good D44 or a 9"
Parts for the 50 are not as easy to locate and the wheel bearing assembly is weak. ROCKWELLS!
#4 | ||
Stinkin Bastige
Nope, no rockwells. Don't even know what they are. no nope nuh uh
Your wifes pimp!
Also a good idea is to learn to drive before going big......all these people go on one or two rides and the think they just need to be bigger. Some of the best rides can be on 31's and stock axles.
But if you must a good swap for a TJ is a set of F-350 axle 77-79 D60's
#8 | |
GRAB A SNATCH BLOCK!!
35s with no off roading
