Will work for Jeep parts!
Problem with a 89 xj lift
I am doing a lift for a kid I know and we got the front done and have hit a bit of a snag. The bolts that attach the leafs to the frame are spinning. What is the best way to get these out?
remove the rear hanger and walk the spring up and down while using an impact or air wrench to spin the bolt with as little pressure as possible. once it starts to come out alittle you can get a pry bar behind it or a large boxed end wrench dropped behind the bolt head and a BFH .
These can be a real pain in the arse if I remember correctly. Isn't the nut inside of the uni-body ? |
Yeah Sarge it is hidden inside there. Basically cut a hole and get it out then weld a new one back in and cover your hole. its a ***** bud enjoy
Hey guys thanks for the help.
