Old 07-24-2008, 10:44 AM   #226
Are ya finished yet? Bringin it to the core event? I would like to see it!
Old 07-24-2008, 10:45 AM   #227
Ok, due to popular demand, i put some extra support around the tanks. This should take care of any possible issue on a rear endover...
Lines up well with the angle of the line of the back of the chassis. Came out very well i think.
I wasn't excited about adding this as i was afraid it would kill the lines of the back of the chassis. But, after seeing how it turned out, i'm happy with it.
Old 07-24-2008, 10:54 AM   #228
ok, started all my panels... man, what a time consuming ***** pain in the ass this has been... but, very rewarding. With each one i add, it looks more like a completed rig and gets me all giddy to get it done.
Some will say i'm going WAY OVERKILL, but I am using .125 5052 aluminum for all the panels. It is much harder to bend / break, but safer when it comes to things like keeping driveshafts out of the interior compartment, etc.
The interior floor panels were especially difficult with all the seatbelt and seat mount tabs etc to cut out for. And the ones that i have left to do on the inside require some tig work and multi plane breaks, etc.
Old 07-24-2008, 10:59 AM   #229
exterior panels can chew up some sheets of aluminum in a hurry, that's for sure... and at $200 each for a 4x8 sheet, it hurts.
Here is the rear inner panel, with my super fancy "fuel level indicator" cutout. With the see thru tanks, i will be able to look into this cut and see the level of pane in my tanks.
I forgot to do it to the passenger side before putting it on, will get it when i disassemble i guess.
Old 07-24-2008, 11:04 AM   #230
The top plates in the back really add a finished look to it.
I guess i get a little overzealous with the tabs and bolts, since they are 3/8. Probably dont need half as many as i'm putting in. But i hate panels that rattle, and everything else is so overkill on this rig there is no reason to stop now.
Old 07-24-2008, 11:10 AM   #231
And the most stressful panels to cut, the sides... since the tow of them eat up most of a whole sheet of plate, i measured 38 times and cut once. Putting these panels on have put a new drive to finish this rig. Standing back and seeing it take actual shape changes things.
Old 07-24-2008, 11:23 AM   #232
And the "piece de resistence", the finishing curve rear panel... finishes the rear nicely. Was gonna leave them off, but now that i see them there, can't imagine it without them.
Now, decision; do i paint the flat panel behind this curved panel, or leave it raw aluminum so that the panel in front stands out more...? opinions?
Old 07-24-2008, 11:26 AM   #233
Have to do the other side panel, and drill and bolt them both. Then the very rear panel, the bottom side of the third seat, bellhousing tunnel, and tcase cover area.
Some of the tcase area isn't going to be pretty, but it will be covered with seats, so not really concerned about it.
Old 07-24-2008, 01:23 PM   #234
very nice....
step cutout?
Old 07-24-2008, 01:30 PM   #235
marked for, not cut yet (obviously)... without it, would be a difficult entry.
Old 07-24-2008, 01:46 PM   #236
Startin to look like ole truggy!
Old 07-24-2008, 01:52 PM   #237
i can't even think of anything to say...
Old 07-24-2008, 02:30 PM   #238
Scott, did you ever buy a rig yet?
Old 07-24-2008, 04:21 PM   #239
RuffedUpXJ
RuffedUpXJ's Avatar
Looks good CW. The panels to clean things up and make it look more complete. The tons of time you spent on the panels are paying off they look good.
Old 07-25-2008, 01:51 AM   #240
JET455
Your wifes pimp!
JET455's Avatar
What are you smoking?
Old 07-28-2008, 11:05 PM   #241
tinbeater
tinbeater's Avatar
Hey Mike.
Have you give up on this project yet? been 4 days with no updates
Hurry up and lets go break something.
Old 07-29-2008, 12:48 AM   #242
spent the night tonight installing my banks stuff...
six gun w/ pda
monster dual exhaust
cold air box
etc...
fun.
Old 07-29-2008, 02:25 AM   #243
ok, few more pics... here are some shots of the sides completely done 9minus footholes) and bolted on, including the rear curves... I think it looks pretty damn good... i'm happy.
Old 07-29-2008, 02:29 AM   #244
couple shots of the panels under the rear seat. these sucked royally to make...
And here are a couple different angle shots of the propane tank mounts in case anyone was interested.
Old 07-29-2008, 02:34 AM   #245
Some folks have been asking what i cut all of the panels with...
I bought this ridiculously bad ass Milwaukee circular saw for metal. has a chip collector, and cuts thru .125 aluminum like it's not even there. Straight as an arrow, looks as good as a machine shear.
For the curves i am using a standard jig saw with a coarse wood-cutting blade in it. Works like a charm.
Old 07-29-2008, 02:36 AM   #246
Coby
Coby's Avatar
sick sick sick
Coby is offline   Reply With Quote
Old 07-29-2008, 04:04 AM   #247
Originally Posted by Coby View Post
sick sick sick
Thanks for all the help, my little mexican.
Old 07-30-2008, 09:57 AM   #248
Old 09-24-2008, 12:15 AM   #249
done yet?
Old 09-24-2008, 10:24 PM   #250
Thanks for the reminder of how slow i am at building this thing. I have moved my shop back to my home shop, and spent two weeks doing that.
Oddly enough, i did some work on it today, and will be heading back out in a little bit to do some more.
No, not done. Won't be for a while.
