Old 08-11-2008, 11:15 PM   #1
cincykid
cincykid's Avatar
Balance A Super Swamper I need help
I just put on a set of S S LTB's 33x13.50x15 and they shake so bad I am thinking about taking them off. They will not balance on my balancer it wants me to put on like 30 oz of weight...... Can anybody tell me if they can be balanced or am I stuck with the shakes.......
cincykid
cincykid is offline   Reply With Quote
Old 08-11-2008, 11:29 PM   #2
maddhatter
maddhatter's Avatar
They make bb's to put in the tires to balance them.
Call around to a few tire places they should be able to hook you up.
I know some guys just use real bb's.
Old 08-11-2008, 11:30 PM   #3
Airsoft BB's
Old 08-11-2008, 11:45 PM   #4
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Airsoft BB's
Yep, I put airsoft bbs in my 38s on H1 beadlocks and it worked well. I just picked them up in wal-mart. 30oz does seem like a lot though, I put 16 oz in mine and that was more than what I thought would be necessary.
Try rotating the tire on the rim and see if that brings it closer.
1994 YJ, 4.0, 5 speed.
Old 08-11-2008, 11:53 PM   #5
cincykid
cincykid's Avatar
So just put plastic bbs in the tire and that will balance the tire? How dose this work? How much in each tire?
Old 08-12-2008, 12:42 AM   #6
use 6 oz per tire of Air Soft pellets . That is about 1/4 of a zip lock bag full ( Ha I said quarter bag ! ) . I have run them in my Iroks since new and they balance great even at high way speeds.
Old 08-12-2008, 09:03 AM   #7
JeepHD
JeepHD's Avatar
As you speed up the bbs will go to the lightest area of the tire bringing it in balance. Great for off road tires, that way if it is spins on the rim or you cut a chunk out of it, there is no need to have them rebalanced.
Here is a chart that may be helpful http://www.innovativebalancing.com/BigTirechart.htm
Seems to call for 8 oz, I would put 10 oz myself to be safe.
Old 08-12-2008, 06:18 PM   #8
cincykid
cincykid's Avatar
Thanks for the help It worked pretty well I put 10 oz in each They don't shake nearly as bad.
Thanks again cincykid
Old 08-13-2008, 12:13 AM   #9
kb9qdi
Storm Chaser
kb9qdi's Avatar
We use Equal packs at our shop and they work very well. I've used them in 40's, 24.5 etc with no problems.
http://www.imiproducts.com/equal/index.aspx
Old 08-13-2008, 10:01 AM   #10
wish i had put some in mine before bolting them all together... really want to balance them, but dont really want to break them down again...
maybe i will do a water/antifreeze
Old 08-13-2008, 12:43 PM   #11
I also just put the regular ol' BB's in my 39.5 Swampers, and several others I know use the same method with good results. I had mine up to about 45-50 mph this weekend coming back from the trail (10 psi in the tires) and would only get a very mild vibration every once in awhile.
Old 08-13-2008, 01:38 PM   #12
So.......when do you think you will really
need to worry about balanced tyres ?
Come on you can tell us.
fall crawl ?
Old 08-13-2008, 01:49 PM   #13
fall crawl ?
Which year?
Old 08-13-2008, 02:09 PM   #14
fall crawl prolly not doable. My only goal be to have it driving before the first snow of this year. I will have more time to work on it soon tho.
Old 08-13-2008, 03:15 PM   #15
cincykid
cincykid's Avatar
What kind of pressure do you run in them for street driving?
I have 33x13.50.15 S S Ltb's
Old 08-13-2008, 03:38 PM   #16
I am able to run 9lbs. in 42'' bias ply irocs at 65mph with no problems. Not balanced and amazingly smooth. Not sure why but maybe lucky or something.
Old 08-13-2008, 03:50 PM   #17
JeepHD
JeepHD's Avatar
I would guess in the 20lb area,but it varies depending on vehicle weight, type of tire, rim width, etc.
I always heard to pump them up to suggested and then when on the vehicle run them thru water and then to dry concrete. Continue checking and decrease pressure until you get a good even tread contact across the hole tire. Front and rear may be different due to weight differences.
Old 08-13-2008, 03:52 PM   #18
air pressure
start with about 23 -28 psi and drive it then look at the contact patch of the tire and adjust from there. if you put to much air in the rolling resistance will be good for milage but not the tire wear in the center.
Old 08-15-2008, 12:52 AM   #19
4RunnerAdam
4RunnerAdam's Avatar
How loud are the BB's when you stop at a stop light?
Think you could add them through the valve stem with the valve core removed?
Old 08-15-2008, 01:51 AM   #20
The steel ones are loud enough to be annoying. I think the airsofts are pretty much silent.
And you'll really want to break the bead to install em. It's really not that bad...
Old 08-15-2008, 02:23 AM   #21
air softs will NOT fit in the valve stem .
They make a little swoosh noise right before you come to a complete stop.
Old 08-15-2008, 08:29 AM   #22
RuffedUpXJ
RuffedUpXJ's Avatar
They have BB's in a smaller form for motorcycle tires and those actually can go through the valve stem but come in 1 ounce pack and would take for ever and too much money to put in to some 36's Sarge.
Old 08-15-2008, 11:24 AM   #23
I had regular steel BB's, maybe 2-3 oz. (also had rim weights), in the 265/75's on my DD/towrig and never noticed them at all. Currently I have maybe 10-12 oz. in my 39.5's on my Blazer and never noticed them with the top off (half top) and the doors on even with window down, but once I took the doors off for the summer you can hear a small "swoosh" right before you come to a stop while driving through town or the neighborhood. Never notice them on the trail at all.
Even if you can fit them through the valve stem it would take a long time to feed them in one at a time because you are talking about hundreds, if not thousands, per tire.
Old 08-16-2008, 07:25 PM   #24
4RunnerAdam
Gotcha. I'll break a bead. Reset it with ether.
Should I keep the wheel weights that are on there now?
Old 03-09-2009, 12:44 PM   #25
4RunnerAdam
So, should I? Do I need to take all the lead weights off? I'm guessing so.
