Old 11-12-2008, 05:24 PM   #1
sickws6
FRAME REPAIR?? pics
This guy is pretty much giving away this jeep but MY only concern is this section of the frame obviously. Where would I even start going about fixing this?
sickws6 is offline   Reply With Quote
Old 11-12-2008, 05:38 PM   #2
i would start by finding someone with good fab skills unless thats you and if it looks that bad there i would look closer at the rest like on the inside of the frame because it would not be uncommen for ther to be more problems
Old 11-12-2008, 05:59 PM   #3
sickws6
I have decent fabrication abilities I could always learn by trying. The guy said that the rest of the frame is ok , but I am def going to do a good inspection
Old 11-12-2008, 06:01 PM   #4
jfiscus
jfiscus's Avatar
doesn't look that bad if that's all there is, shouldn't be to hard to weld a couple plates in there.
Old 11-12-2008, 06:55 PM   #5
maddhatter
maddhatter's Avatar
Yea that is a super easy fix don't freak a couple plates a a couple hours and it will be good as new. I have had to do the same thing to a few CJ frames over the years. Also, make sure you check around the steering box.
Old 11-12-2008, 08:27 PM   #6
sickws6
Cool that gives me some excitement about getting this jeep. its a 94yj 2.5l ax5 The guy is asking 1200 he says it has some other issues such as the rear end locking up after bout 10 min of driving then it will free back up, brakes? bearings? Its also hard to get into first but shifts fine and the transfer case shifts hard.
Old 11-12-2008, 08:44 PM   #7
sickws6
Everyone on jeepforum is flipping out saying that It would need a new frame and stuff.
Old 11-12-2008, 08:50 PM   #8
MrShoeBoy
$1200 is too much. I wouldnt pay more than $700 for a 4 banger YJ that NEEDS a decient amount of fab work.
What do you plan on using the Jeep for? If you want the title and tub and plan on building the thing up then cut off the rear section and trim the sheet metal back, add some tubes, and call it a buggy! If you want a mild wheeler that you can daily drive, then you should really look for something else in better condition. Just my opinion...
AARON
91 MJ Under construction
Old 11-12-2008, 08:58 PM   #9
sickws6
AARON
Well here is a picture of the jeep the body is in nice shape, my plans are to make a mild streetable rig first.
Old 11-12-2008, 09:29 PM   #10
MrShoeBoy
So is the frame in that one spot the problem? Like no rust anywhere else?
Hmm...I might pay $1000 for that and dump in 5 hours of fab work. Looks like a nice find
AARON
Old 11-12-2008, 11:15 PM   #11
that is VERY common for them to rust there. chop it and fish plate it. i'd check the rear spider gears, they are notorious for that too. it definitely isn't safe as is though, use that as a bargaining point to get him to lower that price, you will lose the rear spring like that trying to drive it as is. simple fix to someone that can weld, but a HUGE expensive looking problem to 99% of the people out there. i wouldn't hesitate on it for under $1000.
Old 11-12-2008, 11:51 PM   #12
sickws6
Sorry for my ignorance what do you mean by fish plate?
Old 11-13-2008, 12:55 AM   #13
I'd buy everyone I could get for that price with that kind of frame rot !!! very easy fix . The rear ..... well it's a D-35 with 4.10's ( a dime a dozen ) . All the AX-5's shift alittle funny ( grind , hard shift when cold ..... ) .
Buy it , fix it , and wheel it or sell it and put some money in your pocket for the next one.
Just google fish plate .... I don't feel like explaining it , but it's simple.
You can sell the hard doors for half the purchase price !!
Old 11-13-2008, 02:34 AM   #14
only thing that would keep me from buying it is the motor. the frame is an easy fix.
don't drive it home, tow it. use that as a bargaining point as well. it's not road safe in its current state.
Old 11-13-2008, 11:17 AM   #15
sickws6
Does anyone want to make a few bucks and tow it for me? IT is in houston ohio which is bout 75 miles north of Hamilton. I am unfortunate enough to not have a tow vehicle.
Old 11-13-2008, 11:48 AM   #16
I may be able to tow it for ya. How much $ are we talkin? My diesel gets bad mileage!
Old 11-13-2008, 12:02 PM   #17
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
That is literally right across the road from me. I will be traveling to the Lebanon/Red Lion area several times next week. I can get it to there for you for reasonable amount, not sure if I can get it to your home because I will have another employee with me each day.
I checked it out. Definetely needs the frame repair and probably a new rear end. Just pick up another D35 with 4.10s and swap it in or an 8.8 with 4.10s If you keep the D35, keep the shafts out of the current for spares.
I'll PM you my info.
1994 YJ, 4.0, 5 speed.
Old 11-13-2008, 04:34 PM   #18
jfiscus
jfiscus's Avatar
I can tow it if you can cover gas + whatever extra we work out.
I live in Middletown so I'm not too far from ya.
513-317-2314 Call me this evening & we'll work something out.
I'm looking for a torpedo heater if you can get ahold of one?
Old 11-13-2008, 06:24 PM   #19
sickws6
Well I broke down and bought the jeep today! I think it is definitely worth what I paid for it. Jfiscus and jeephd whoever gets the lowest bid gets to tow it lol jp. Actually I am trying to get a hold of one of my buddies who has a trailer, but I might be getting with you guys soon. I am excited to start tearing stuff down! The rest of the frame was ok I even asked if I could have a hammer to beat on it to make sure no soft spots anywhere and there wasn't other than both side rear obviously.
Old 11-13-2008, 07:48 PM   #20
that is VERY common for them to rust there. .
???? Mine hasnt had any problems. I have never seen frame rot like that on a YJ.
Old 11-13-2008, 10:09 PM   #21
cincygman
My buddy had a CJ rust out just like that back in 1978 (yeah, I'm an old fart) we found out it was rusted when the shackle ripped loose going up a hill and punched through the gas tank. It was an easy fix once back at home, some box tubing and about six hours of cutting, drilling, welding then just like new or better
Romans 7-8
Old 11-13-2008, 10:55 PM   #22
sickws6
yep! it will take a few hours of metal work!
Old 11-14-2008, 08:30 AM   #23
JeepHD
JeepHD's Avatar
I saw it was no longer sitting out along the road last night, figured someone bought it. What did you end up getting it for?
Later
Josh
Old 11-14-2008, 09:57 AM   #24
acousticrawk
The MacDaddy
Send a message via AIM to acousticrawk
i concur. CJ's used to rot back there bad, but i have never seen a YJ rot like that. even a salt belt YJ. i have done several repairs like that on CJ's. just completely cut the rear of the frame off, buy some .25 wall or bigger (if you want) rectangle stock thats the same size as the frame, tac it, get it good and straight, then weld it to the existing frame. once your done with that, grind the welds, and fishplate. now is a good time to move your shackle hangers under the frame too. about 25 bucks worth of shackle hangers? and it will give you a little lift in the rear. MAKE SURE to paint it all when your done to help prevent it from happening again. take less than a day to do both sides from my experiance, with 2 people or so. good luck, keep us updated.
acousticrawk is offline   Reply With Quote
Old 11-14-2008, 10:24 AM   #25
Have to admit, I was thinking the same as Tony... haven't seen YJ rot like that...
Congrats on the purchase... Fix, upgrade, break, repeat.
