Old 02-10-2009, 01:13 PM   #1
Bear Chow
Jeepless
Bear Chow's Avatar
front & rear bumper
I'm going to take a stab at making simple square tube front and rear bumpers with 3" hitch. How thick should the tube be without being overkill?
Thanks
Paul
Old 02-10-2009, 03:45 PM   #2
maddhatter
maddhatter's Avatar
What size tubing?
1/4" wall is heavy but strong.
Old 02-10-2009, 03:56 PM   #3
Bear Chow
Jeepless
Bear Chow's Avatar
I was planning a trip to the scrap yard to see what I can find. 2x3 3x3 2x4 I thought 1/4" might be on the excessive side. So I figured, I would see what a typical thickness would be.
Old 02-10-2009, 04:23 PM   #4
<---- big fan of 1/4" wall or greater...
but I know I'm strange...
Old 02-10-2009, 05:44 PM   #5
maddhatter
maddhatter's Avatar
A pretty good rule is, Pick it up if it's not heavy ass hell? Find one that is!
Old 02-10-2009, 08:34 PM   #6
3/16 works well and there is a special receiver hitch stock that doesn't have a seam inside of it. It is pricey but a foot will make two hitches.
Old 02-11-2009, 11:52 AM   #7
KennyTJ
The Pirate
KennyTJ's Avatar
Find an old crappy trailer hitch and cut the reciver and tow chain loops off and use them in your build. Might be able to get a crappy old hitch for free.
3/16" is thicker that what most manufacturers use.
Old 02-11-2009, 12:27 PM   #8
tony
Guest
Posts: n/a
ive always used 3/16th. and you can pic up receiver weld in fittings at tractor supply and harbor fraight. what thickness can your welder handle? most 120 migs are 3/16th.
Old 02-11-2009, 06:29 PM   #9
I've got 5-10' lengths of 3"x3"x3/16 wall tube ...$30 each
They originally had base plates welded on them that I cut off with a torch.
