Old 04-26-2009, 08:10 PM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
car trouble any ideas would help
my wife's car (93 Nissan Altima) sometimes dose not get spark from coil other times it runs fine
have tried swapping out coils ( same thing happens) also tried swapping out the ignition control module
it seems to do it after the car runs for a while it has died a few times then not stard back for a while
any ideas could help
thanks
86 Ford Bronco
Old 04-26-2009, 08:27 PM   #2
berrym2
berrym2's Avatar
is there any oil inside the distributor,under cap. i've seen oil leak thru the shaft seal and get onto the pick-up and cause similar problems.
berrym2 is offline   Reply With Quote
Old 04-26-2009, 08:37 PM   #3
SixFtUnd
Danny Beach
SixFtUnd's Avatar
the coil is not fireing so it's before the distibutor
86 Ford Bronco
Old 04-26-2009, 11:07 PM   #4
berrym2
berrym2's Avatar
the pick-up inside the dist tells the coil when to fire
Old 04-27-2009, 08:34 AM   #5
SixFtUnd
Danny Beach
SixFtUnd's Avatar
ok thanks will try that
86 Ford Bronco
Old 04-27-2009, 12:09 PM   #6
Cps?
Old 04-27-2009, 06:13 PM   #7
SixFtUnd
Danny Beach
SixFtUnd's Avatar
What do you mean Cps?
86 Ford Bronco
Old 04-27-2009, 08:17 PM   #8
CPS = Cam position sensor! May be the ticket I tell ya.
