Old 10-11-2009, 09:42 PM   #1
TheJeepGuy
A/C compressor elimanation
Does anybody know of a bracket/idler pulley to install in place of the a/c compressor on a Jeep 4.0? I did a search on Pirate,but not much help.
TheJeepGuy is offline   Reply With Quote
Old 10-11-2009, 10:03 PM   #2
http://www.cincyoffroad.com/forum/showthread.php?t=4038
Old 10-11-2009, 10:28 PM   #3
TheJeepGuy
Thanks for the reply,but.......I don't want to add another alternator,just do away with the a/c compressor.
Old 10-12-2009, 06:58 AM   #4
Get a smaller belt and play with the routing. Use a cut belt for measuring to get the length right.
Old 10-12-2009, 07:34 AM   #5
Youdont realize how nice onboard air is until you have it. Why not try that?
Old 10-12-2009, 07:55 AM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
Youdont realize how ne onboard air is until you have it. Why not try that?
I made up a OBA system and it is quite nice to have it you have some things sitting around. Heck i uses it to blow up our tow-behinds for the boat when I tow the boat with my Jeep. there are many uses for it.
http://www.jeepforum.com/forum/f11/my-oba-529670/
Old 10-12-2009, 08:32 AM   #7
there is a pully that came on some MJs that replaces the AC pully.
I know I had one with it a couple years ago, but may be rare to find in a junkyard.
Old 10-12-2009, 09:59 AM   #8
TheJeepGuy
Thanks for all the ideas,on board air can be a great add on.Several guys I wheel with have it on their rigs.Seems like they use the older York style compressor for oil reasons.For now I think I will go with Truggy's idea and reroute the belt and keep everything turning the right direction.I was just hoping to find a direct bolt in idler and use the same belt.Surely not all 4.0 jeeps had a/c.Thanks again for all the replies.
Old 10-12-2009, 10:25 AM   #9
RuffedUpXJ
RuffedUpXJ's Avatar
You could always make a mount for your Alt. where the AC comp is and then your alternator will be farther out of the water and dirt. but I am not sure if an idler pulley there or up top will be easier.
Old 10-12-2009, 02:08 PM   #10
TheJeepGuy
a/c delete
Found a thread on Pirate pertaining to moving the alternator to the a/c location,and another one pertaining to a/c delete.Both threads are in the Jeep/Cherokee section on page 17.The threads also have good pics.Sounds like a good idea to move the alternator up and away from the water and dirt.
Old 10-12-2009, 04:27 PM   #11
yes, it is a good idea, or else get a front skid plate, or you'll be replacing the alt every couple trips out when you get in the deep stuff.
Old 10-13-2009, 12:11 AM   #12
Or at least climbing under the rig to smack the alt with a hammer, and knock all the mud out of it...
Been there, done that, got the mud in my eye to prove it...
Old 10-13-2009, 05:22 PM   #13
I understand the alternator mount bracket from a 2.5 (Four banger) will bolt up in place of the a/c mount bracket on the 4.0. Then you just move your existing alt to the top bracket. Might shoot Commanchedude a Pm he done this mod a few years ago..
Good Luck
