01-13-2010, 12:39 AM | #1 |
Dana 30 hub conversion
Can I take Cj outer knuckles and do a hub conversion on my Xj and then put the bolt pattern adapter spacers on the back to make it all work?
01-13-2010, 07:49 AM | #2 |
no,, the ball joint in a CJ go in the outter knuckles and the XJ are pressed into the inner knuckles.
But I did see were someone is makeing knuckles for the XJ(and other jeeps that use that knuckles) that use all the older hub parts |
01-13-2010, 09:29 AM | #3 |
Should have just got a CJ, they last forever.
01-13-2010, 09:59 AM | #4 |
why? I would assume running a full-time front locker?
01-13-2010, 10:49 AM | #5 |
http://www.reiderracing.com/product_...ducts_id=32424
here is a link to the knuckles I was talking about |
01-13-2010, 08:50 PM | #6 |
For now i want to weld it and possibly put some good shafts and joints in. I also dont want to deal with the unit bearings
01-15-2010, 03:14 PM | #7 |
If you have a CJ 30 couldn't you use the inner C's and knuckles on the XJ 30 ??? just an idea .... prolly alot more work then it's worth but an idea.
01-15-2010, 04:13 PM | #8 | |
Scotty has been wanting to do this for a while and has looked into it a lot. Maybe he will speak up |
01-15-2010, 05:11 PM | #9 | |
build it,not buy it!
the tube diameters are the same- you can carefully cut off the xj C and persuade the cj C onto the xj housing. however,you axle is essentially narrower now,so youll need a custom inner shaft i have had this project on the back burner for a long time now,lol... in order to use stock xj inner shafts you need to space the cj inner C out a couple inches,in whatever manner you are comfortable. anywhere from changing out the tube ( ) to sleeving it with something. ive got cj Cs with a couple inches of tube still attached. when i determine exactly how much wider it needs to be im planning to weld the 2 tubes together,then sleeve the joint with 2 halves of tubing(welded together,and to each tube) another method that would be alittle more effort(unless you own a machine shop) would be to extend the xj housing with a bigger tube,then machine the cj inner Cs to slide over that larger diameter. if you have any other questions let me know,or of it helps you any i can snap a few pics later. right now i gotta get movin to go help dave pick up his new junk
scotty 85 grand wagoneer(whats left of it) 77 scout II truggy 84 chevy "home made crewcab" Delightfully Tacky,Yet Unrefined |
01-15-2010, 05:27 PM | #10 |
Nope but it sounds like more than I want to get into.
Did you ever do anything with that Super Duty axle?
01-15-2010, 11:03 PM | #11 |
nope im a slacker. too many irons inthe fire
01-16-2010, 02:17 AM | #12 |
I don't even like the SuperDuty axle under my SuperDuty. I certainly wouldn't infect a project rig with one...
