Old 08-17-2010, 08:40 PM   #1
mossyoaktj
mossyoaktj's Avatar
95 cherokee overheating
dad has a 95 cherokee with the 4.0 in it. its been having overheating problems. so far he has replaced thermostat , raditor, good waterpump. he just dropped a good little bit of money and too the head off replaced the head gasket. and.....still the jeep is overheating. any ideas
UNITED STATES MARINE
Old 08-17-2010, 10:34 PM   #2
BiggDaddy
BiggDaddy's Avatar
check anti-freeze?
This sounds simple, but have you checked the anti-freeze? That was the problem with mine, all I had to do was add some green stuff, again and again. Turned out to be a hole in the radiator, but some goop stopped that. Haven't had any problems since.
Good luck!
BiggDaddy
'82 CJ-7, 6" lift, stock axles
258, 35x15.50x15 TSL/SX
Rustoleum Gray
BiggDaddy is offline   Reply With Quote
Old 08-18-2010, 02:32 AM   #3
mossyoaktj
mossyoaktj's Avatar
Good luck!
BiggDaddy
yea he has also flushed the system as well.
Old 08-18-2010, 02:37 AM   #4
Fan clutch?
When does it overheat?
Old 08-18-2010, 06:40 AM   #5
mossyoaktj
mossyoaktj's Avatar
Fan clutch?
fan clutch is good, and it has electrical fans as well. dad says it tends to overheat a lot on the open highway
Old 08-18-2010, 09:19 AM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
With it being on open highway, where there is plenty of air flow across the radiator, that the water pump is the suspect since it isn't spinning as fast as running through the gears say hitting 3k or so but only hitting just over 2k. Or you may have a build up some where. POssible take the water pump off and have a look at the veins and make sure nothing spun.
Also, whats over heat to your dad? pinning the gauge or riding at 210?
Old 08-18-2010, 11:24 AM   #7
Just last night I had to put a water pump on my sons 94 XJ , it has been over heating sitting in traffic and while flogging it on the trails and yesterday the thing started making all kinds of noise. Turns out the bearings in the water pump were shot....... the water pump was only 3 months old.
Old 08-18-2010, 06:52 PM   #8
mossyoaktj
mossyoaktj's Avatar
to dad overheating is pegged out to the red. but i kno hes removed the water pump and said it looks fine. ill mention it again to him tho about the water pump, the only thing he told me is that the fins looked good and all.
Old 08-18-2010, 07:02 PM   #9
mossyoaktj
mossyoaktj's Avatar
so im on the phone with dad and i have verified that it doesnt over heat while drivin around town just on the highway. his next option is getting the head shaved down.
so is there a chance that the head is slightly off level and letting build-up into the thermostat housing or is it most likely the water pump not spinning to the correct rpms while on the highway
Old 08-18-2010, 08:26 PM   #10
eighty3bronco
anywhere but there
eighty3bronco's Avatar
this scares me. just because it looks "fine" does not mean that it is.
Old 08-18-2010, 10:32 PM   #11
mossyoaktj
mossyoaktj's Avatar
yea me too. but i dnt want to tell him to replace it and it not be it and still have to mill the head down.
Old 08-18-2010, 10:32 PM   #12
mossyoaktj
mossyoaktj's Avatar
any easy way to tell on the 4.0 if the water pump is workin up to par
Old 08-19-2010, 12:53 AM   #13
hes removed the water pump and said it looks fine...
I can not imagine tearing all the way into it, and not replacing a $25 part.
I mean, I'm cheap. Really cheap.
But I'm really lazy, too.
Old 08-19-2010, 02:04 AM   #14
mossyoaktj
mossyoaktj's Avatar
being a cheaper route will be a better way to go. and even if it doesnt work atleast you got new parts.
Old 08-19-2010, 09:50 AM   #15
jfiscus
jfiscus's Avatar
sounds like a clogged radiator or bad pump.
He did the head gasket w/o having the head checked out? I don't think this is the issue though if the pressures are the within tollerance on the cylinders.
Going down the highway the fans aren't doing much, as more air is flowing through on its own due to wind. And it's not overheating around town in slow driving, so the fans seem to be pushing well. So, I would assume a water pump (or clog somewhere) or a clogged radiator/line. try flushing it again.
Old 08-19-2010, 09:20 PM   #16
tinbeater
tinbeater's Avatar
check and see if the fan on the water pump isnt on backwards.
Old 08-20-2010, 10:05 AM   #17
is this cherokee white with the woody decals in fairfield township? I have seen one being worked on and have wanted to stop by to see what is up.
Old 08-20-2010, 11:32 AM   #18
mossyoaktj
mossyoaktj's Avatar
not dad lives out in moscow in the middle of the boons. the cherokee is dark grey.he hasnt been able to work on it much hes been workin out of town.
Old 08-22-2010, 12:13 AM   #19
8UP
Did he get the right water pump? Serpentine pumps spin the opposite direction than conventional belt types.
Old 08-22-2010, 12:38 AM   #20
Said he looked at it and put it back on, same one as before.
Old 08-22-2010, 10:28 AM   #21
mossyoaktj
mossyoaktj's Avatar
ok he just flushed the entire system again. new water pump, then flushed again. so we'll see how it goes
Old 08-22-2010, 12:38 PM   #22
Does he has something on the front that is restricting the air flow at highway speeds?????? I know my 8274 winch will do this on the highway if I'm running over 70mph.
Old 08-22-2010, 11:20 PM   #23
If the tranny was slipping, making the engine run faster/harder at highway speeds than normal, would it cause overheating?
Really don't know, I'm grasping at straws here...
Old 08-23-2010, 01:07 AM   #24
mossyoaktj
mossyoaktj's Avatar
completely stock cherokee. its just a dd. no the tranny doesnt slip what so ever, the jeep runs superb witht he exception of the over heating. he said after he flushed it and put a new water pump in it its running way cooler than before but i havent heard if it was over heating on the high way any more.
Old 08-23-2010, 09:06 AM   #25
Is this a closed or open system?
