Old 10-06-2010, 04:52 PM   #1
truk
truk's Avatar
help me build my sidekick!
ok i guess im jumping in with both feet! bought yota axles . planning on running 33s or 35 what ever i can find used prob. my problem is suspention. i guess some sort of jeep leafs would be good but why not 3 link the front and 4 link the rear. i cant find a vendor with a kit so i guess i would have to build either way. you guys are the experts ! give me your opinions . thanks matt
Old 10-06-2010, 04:59 PM   #2
T-bird
T-bird's Avatar
What are you looking to do with your new toy? Is it going to be off road only, some street or Daily Driver? What kind of trails do you hit? Woods, Rock or Mud? How much are you looking to spend.
Once you tell everyone those basic questions they can tell you how you should build it.
Old 10-06-2010, 05:27 PM   #3
Nuts's Avatar
Pretty sure trail tough sells a coil/link kit for trackers and sidekicks, but it'll probably cost more than you paid for your entire rig.
Old 10-06-2010, 07:06 PM   #4
flatlander757
Fartface extrordinair
I used www.ruffstuffspecialties.com for a LOT of parts and heims and brackets for my Jeep... top notch stuff, great customer service, and it's not insanely priced whatsoever
Call the number on the home page, Dan is great to deal with... it's nice when you call a company and the owner is the one answering the phones 90% of the time.
Old 10-06-2010, 07:58 PM   #5
truk
truk's Avatar
some street use i driver it to work now and then about 20 miles no interstate, trail wise ,ive been to badlands for zukimelt last 2 yrs in a mostly stock sidekick, looking to do more with it. really dont want to spend 2700 on kit from trail tough when they tell you its not good on the road. the only things definite is yotas with grizly locker rear and lock rite front and 5.89s other than that not sure. tires size 33s or 35s i guess.
Old 10-06-2010, 08:28 PM   #6
truk
truk's Avatar
i guess i want a rig that i can go on trips with core and not be a hinderence.
Old 10-06-2010, 09:28 PM   #7
Nuts's Avatar
Find a set of 4cyl TJ coils, barnes4x4 has rod ends for pretty cheap, get some 1/4" plate for tabs and brackets, and some 1 1/2' DOM tube for links and start cuting and welding
Old 10-07-2010, 01:20 PM   #8
If you get hung up I'll throw out a line and drag you out with my little Chevy...
5.89's and 33's would be be screaming on the highway wouldn't it. It would crawl good. I'm running 5.38's with a 40" tire and my crawls good. Mine doesn't like highway speeds any more. :mad:
Old 10-07-2010, 01:40 PM   #9
Pic of one of my fav kicks
Name:	IMG_1239 (Small).JPG
Old 10-07-2010, 01:57 PM   #10
5 spd sidekicks come with 5.12 gears from the factory and 4.62 in autos so the 5.89s will work ok. the 4dr sidekick above was mine and was a 2wd 5spd when i started. i put yota axles with the stock 4.10 gears and added a samurai divorsed t case which has a high range of 1.4-1 and will give you a final drive of 5.79 with the 4.10 gears and pulled the 35" tires just fine at highway speed. if i were you i would find a 2wd trans and do the same with a samurai t case because its cheaper and has more gears to chose from and also gets rid of the slip yokes. or you could spend alot of money with trailtough and by there undertaker case for $1300 and still need to do alot of mods. as far as suspention i linked mine and it was great on and off road but will take a bit more thought and money to do it correctly.
good luck on your build
Old 10-07-2010, 03:13 PM   #11
KennyTJ
The Pirate
KennyTJ's Avatar
Dan is a great guy. He'll give you 10% off usually with no issue if your in a 4x4 club. He has the best deal around for complete heim sets!
Old 10-08-2010, 04:26 PM   #12
truk
truk's Avatar
if could get mine to set like that i would be happy. i like the looks of it.
Old 10-08-2010, 04:28 PM   #13
truk
truk's Avatar
well this is my first off road build should be interesting! ive built drag cars so it will be diffrent.
Old 10-09-2010, 06:55 AM   #14
drmeece
drmeece's Avatar
I like that one too Lisa
I got a jeep
Old 10-09-2010, 05:05 PM   #15
donaldcon
donaldcon's Avatar
actualy only the 3speed autos have the 4:62's MOSt others had 5:12 reagardless, unless you got the super rare 5:61's.
Old 10-11-2010, 09:07 AM   #16
well thats interesting because my auto 96 x90 has 4.62s in it and the 95 4 dr auto that i had also 4.62s the rest of them just passed through my hands but that was just my experience from working at a acura/suzuki service department from 1989 untill they ditched suzuki in 96 and the 5.61s i did see only in the 89 kick with the carbed 1.6 and you are correct those were few and far between
Old 10-11-2010, 08:29 PM   #17
donaldcon
donaldcon's Avatar
ALL x-90s regardless have 4.62...
Your 4door would either had 4.30's ( if a 3speed) or 5.12's if a 4speed
I have had over 20 trackicks. Only 3 of them had 4.62's and those were 3speed autos. No 4speed auto ever had 4.62's from the factory except for the x-90
as found on zuwharrie
89-98 Trackick gear ratios
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89 2 1.3L carb. 5 speed man. 5.625
89-95 2 1.6L TBI 5 speed man. 5.125
89-95 2 1.6L TBI 3 speed auto 4.625
91 4 1.6L TBI 5 speed man. 5.375
91 4 1.6L TBI 3 speed auto 4.625
92-98 4 1.6L MPFI 5 speed man. 5.125
92-98 4 1.6L MPFI 3 speed auto 4.30
92-98 4 1.6L MPFI 4 speed auto 5.125
94-98 2 1.6L MPFI 5 speed man. 5.125
94-98 2 1.6L MPFI 3 speed auto 4.30
94-98 2 1.6L MPFI 4 speed auto 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
edit: I did say only 3speed autos had 4.62, but I was talking trackicks, not x-90 as this thread isnt about an x-90.
Old 10-11-2010, 08:36 PM   #18
truk
truk's Avatar
oops i was wrong ratio is 5;29 .there from trail gear.
Old 10-11-2010, 08:43 PM   #19
donaldcon
donaldcon's Avatar
A sidekick will barely be able to move with 35's and 5:29's
Assuming you have 5.12's in your sidekick you will wont 6:64 gears on 35's to see "stock" performance and they dont make that low for very many axles.
Even with 4.62's stock youd still want a 5.99 ratio for "stock" performance
unless you put tcase gears in, build a double, or put a bigger engine in you'll be eating up clutches.
Old 10-12-2010, 07:32 AM   #20
--threadjack--
4.62s in my x90 and 3.08 in my TJ. There is just something horribly wrong with that....
--end threadjack--
Old 10-12-2010, 11:18 AM   #21
KennyTJ
The Pirate
KennyTJ's Avatar
--threadjack--
--end threadjack--
You need gearing to make up for lack of Power!
Old 10-12-2010, 12:26 PM   #22
sorry i just started doing this yesterday and i guess i dont know anything about this stuff so i will back off now good luck truk if you need anything send me a pm.
Old 10-12-2010, 12:36 PM   #23
Thumbs up
Hey FLXRATD I still like you even if you are just a boobie I mean noobie!
Old 10-12-2010, 12:41 PM   #24
thanks little buddy. i just dont remember things like i used too. wait who are you again
Old 10-12-2010, 02:13 PM   #25
Squirrel
Barnes4wd.com has some universal link kits. I used one when I linked the rear of my sami.
Rock4xfab has a good kit to put a sami case behind the track/kick case for a good doubler. This will give you a high range reduction and not have to worry about the axle gears so much.
