Old 07-12-2011, 08:35 AM   #1
fordman00
fordman00's Avatar
Who has a diesel and whats your mpg?
Hey everyone just curious how many miles per gallo do you get with your diesel not towing? I have a 99 pstroke stock except exhaust and somehow I'm only getting 10-12 in town and I drive like an 80 year old grandma! it does have bigger tires which may be a factor but still 12 mpg!
Old 07-12-2011, 09:19 AM   #2
race10
race10's Avatar
Talking
I have a 02 extended cab short bed 4x4 cummins empty I'm around 18.5mpg with my gooseneck on I get around 14.5mpg. I have a couple of small mods done to it.
Old 07-12-2011, 09:32 AM   #3
That's bout right for a choke... Put a box on it and it may get a Lil better but not much
Old 07-12-2011, 09:35 AM   #4
fordman00
fordman00's Avatar
That's way my buddy has and his Is about the same.and my uncle has a 6.0 powerstroke and it was getting 17 and I was beating the snot our of it
Old 07-12-2011, 09:42 AM   #5
fordman00
fordman00's Avatar
All the ones I looked at said maybe 2-4 miles per gallOn gain.mostly ts 6 position
Old 07-12-2011, 10:09 AM   #6
Just talked to 2 guys here at work, both completely stock 4x4 versions:
'99 auto - 16 highway, 13-14 city
'00 6-speed - 18 highway, no city info, but about 14 towing 7k on highway
Old 07-12-2011, 10:12 AM   #7
fordman00
fordman00's Avatar
Hmmmm.I dont know, it just irritates me because I know it can do better.I gave a l99 as well ext. Cab 4x4stock except tires n exhaust.
Old 07-12-2011, 12:11 PM   #8
Have you corrected the speedo/odo for the larger tires? If not, you are actually getting more miles out of a tank of fuel
Old 07-12-2011, 12:15 PM   #9
fordman00
fordman00's Avatar
No,I actually have not but I hope to be getting a chip soon and maybe down size my tire size.
Old 07-12-2011, 12:22 PM   #10
eighty3bronco
anywhere but there
eighty3bronco's Avatar
i've got a '99 with the 6 speed two wheel drive i get around 17 combined city and highway. everything is stock
Old 07-12-2011, 01:22 PM   #11
solar1
10
I have an 03' Cummins auto, 2wd and get about 20-21 daily driving mixture and get about 15-16 towing my Jeep running at 70. If I go above 70ish it drops fast. All stock with a Leer Snug Top on it.
Old 07-12-2011, 04:31 PM   #12
oklahomawelder
Tradin' Fool
2010 dodge 2500 4x4 mega cab
16-18 highway or around town 35 mph or 75 mph doesnt matter
But put a 24' GN behind it and BAM bout 8-12
I am running 33's with the odo corrected
I put a 6" lift and 37's on it for about 3 months and took that **** right back off. It Dropped to 12-13 MPG and with me averaging 1000-1500 miles a week that wasnt going to cut it...
Old 07-12-2011, 04:43 PM   #13
I have a 99 with the 6 speed 4x4 on 35s. I get 12 highway, 12 city, and 12 regardless of how much weight I have behind it. I have a ts 6 position and keep it on the 50 horse. Not much difference bt the 50 horse and the.rest of the settings with stock injectors other than the amount of smoke imo. I hope to lower it to a 2 or 4 inch lift (currently an 8") so that should help my milage a little. I want to get it up to around 15.
Old 07-12-2011, 05:47 PM   #14
mike shelton
i just sold my old 97 12 valve 4x4 5 speed x-cab that was getting 25ish empty and around 18 towing. had well over 500.000 on it too. my 03 crew cab is around 22 empty and 14 towing. it is a two wheel auto tho.gabby.
Old 07-12-2011, 06:24 PM   #15
tubehead
I have a 05 Dodge CCLB 3500 single rear wheel 6 speed. On the highway it will all most break 20. Hand calculated it comes in right at 19.97 most of the time. Towing I usually get 14-15. I drive right at the speed limit and run my smarty jr on #2 with an intake and exhaust.
Fordman00, I've had 6 or 7 Powerstrokes. My last one was a 2000 CCSB and the best it would get was 14 and 9-10 towing. They were good trucks but I couldn't get the milage up.
www.roarkfabrication.com
Old 07-12-2011, 07:09 PM   #16
STACK
STACK's Avatar
I got a 96 12 valve and I average about 20 mpg, would do much better if I didn't like smoke lol
STACK is offline   Reply With Quote
Old 07-12-2011, 08:19 PM   #17
hotrod
Diesel guy
hotrod's Avatar
My '00 stroke gets about 15 MPG
My '02 Max gets 24 MPG on the econ tune.
2013 RZR S
Old 07-12-2011, 08:56 PM
Old 07-12-2011, 10:34 PM   #18
fordman00
fordman00's Avatar
I see.my tires are bfg all terrain ta k/o.I know it has potential.lol.just have to work out the kinks and things.
Old 07-13-2011, 07:49 AM   #19
muddinredneck513
muddinredneck513's Avatar
Need to work on that paint job too. Pass side wow!
Old 07-13-2011, 07:59 AM   #20
What size are the current tires?
I agree with the post above about larger and/or more aggressive tires causing a drop in fuel economy, and combined with lift is even worse. But part of that is also because the odometer is now off and you are getting a lower than actual miles reading on the odo (assuming odo/speedo has not been corrected).
For an example, going from a stockish 265/75R16 to a 35ish" tire nets around a 9% difference in distance travelled per revolution of the tire and thus the odo will show 9% less miles. So if you fill up with 20 gallons of fuel and the odo says 250 miles that is 12.5 MPG, however you actually traveled around 272 miles so the corrected MPG would be 13.6. Then include the added rolling resistance, rolling mass, and increased aerodynamic drag for another 1-2 MPG hit.
On my gas 6.0L Chevy 2500HD going from the stock street 245/75R16 to 285/75R16 BFG AT cost me about 1-1.5 MPG with a corrected odo.
Old 07-13-2011, 08:47 AM   #21
fordman00
fordman00's Avatar
I'm sorry but what are you talking about my paint?
And blazer brad I dot know of the top of my head trucks at home and te girlfriend wouldn't even know what numbers to tellme
Old 07-13-2011, 09:38 AM   #22
muddinredneck513
Its a black f250 that's been wrecked on pass side isn't it?
Old 07-13-2011, 09:54 AM   #23
fordman00
fordman00's Avatar
Yes.but it's fixed has some orange peel.
Old 07-13-2011, 11:11 AM   #24
nsscout
2006 dodge cummins 4x4 longbed auto stock tires and everything else
average 17 to 18 mpg on daily commute 75% hwy 25% city
usually cruising 70mph
nsscout is offline   Reply With Quote
Old 07-13-2011, 04:24 PM   #25
bc35339
bc35339's Avatar
My 02 duramax is stock with 128,000 miles on it and I only get 13.5 to 14.5 mpg. How much do I need to spend and what do I need to buy to get 24 mpg?
