Old 01-07-2012, 01:34 PM   #1
u&k metal works
u&k metal works's Avatar
Stak swampers and more Dana 60 s
I've got most of a project for sale I'll post pics asap priced to sell for a buddy he has gone another direction
Stak 3 spd driver side drop 23 spline input $3000
42 inch super swampers 80% tread mounted on new 8 lug wheels with weld on beadlocks $1500
Dana 60s f/r driverside drop 5:38 gears front lockright rear is full spool new Yukon gears and install kits as well as kingpin rebuild kit disc brake on rear$1600 on the pair
Sbc fuel injected out of an 89 truck$400
2 sm465 trannys one 32 spl output the other is 10 spl. $150 ea
Novak adapter for sm465 to 23spl output and round bolt pattern tcase $400
Summit radiator kit new $350
Ceterforce clutch and hydro bellhousing $250
Warn 8274 winch new gaskets and seals cleaned up an gone through$750
3/4 hiem set includes hiems, bungs spacers and jam nuts$100
Set of sunpro gauges used $40
15 gal plasic fuel cell$50
I have more just need to take inventory fell free to ask ?s located in bainbridge oh west of Hillsboro about 19 milesClick image for larger version
ID:	4733Name:  ImageUploadedByTapatalk1325957577.691622.jpg
Size:  29.8 KBName:  ImageUploadedByTapatalk1325957616.876955.jpg
Old 01-07-2012, 04:17 PM   #2
frankensteinxj
frankensteinxj's Avatar
Are the 60s ready to weld perches on and bolt in or do the gears and lockers need installed?
My dad will be interested if they are ready to go.
BYAAH!!!
Old 01-07-2012, 06:43 PM   #3
u&k metal works
They are ready to go the rear has some tabs welded on but can be removed easy enough
Old 01-08-2012, 05:50 PM   #4
u&k metal works
Axles Sold pending payment
Old 01-08-2012, 07:52 PM   #5
frankensteinxj
how many heims you got?
And do you want those rear d44 shafts?
BYAAH!!!
Old 01-09-2012, 12:17 PM   #6
bizeeb65
What wheel diameter size on the 42's? 15? 16? 17?
bizeeb65 is offline   Reply With Quote
Old 01-09-2012, 03:20 PM   #7
u&k metal works
I have one complete set of hiems
And the tires are 42/15/15. Thanks
Old 01-09-2012, 04:35 PM   #8
u&k metal works
Few more items;
Wilwood brake setup used $150
Home built dana60 covers $75 for the pair
Gas pedal assem. $25
Pair of corbeau Baja ss seats new$350
Old 01-09-2012, 04:37 PM   #9
u&k metal works
Size:  31.1 KBName:  ImageUploadedByTapatalk1326141417.803612.jpg
Size:  32.1 KBName:  ImageUploadedByTapatalk1326141443.487108.jpg
Old 01-09-2012, 11:20 PM   #10
YJ60
Seats
Where are you located and available for seats?
Thanks, Teach
YJ60 is offline   Reply With Quote
Old 01-09-2012, 11:38 PM   #11
u&k metal works
Located in bainbridge sorry just sold the seats
Old 01-10-2012, 12:17 AM   #12
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Interested in trading a two speed stak and some cash for the 3 speed?
1994 YJ, 4.0, 5 speed.
Old 01-10-2012, 06:10 PM   #13
u&k metal works
I have made a mistake the stak listed is a pass side drop my apologies
Old 01-10-2012, 06:32 PM   #14
If these parts were for the same buggy, does that mean the front 60 is passenger drop as well?
Old 01-10-2012, 11:36 PM   #15
u&k metal works
Yes carwash it does and I still have these again I apologize for the mix up everything is pass side drop
Old 01-11-2012, 02:08 PM   #16
I'm interested in axles...
Old 01-11-2012, 05:32 PM   #17
Are these axles already built with these gears? I only ask because you mention install kits and kingpin kits. Or are they take out axles that come with these parts to build with? Let me know, I'm interested.
Thanks!
Old 01-12-2012, 02:41 PM   #18
u&k metal works
The axles are built gears installed and all.
Old 01-14-2012, 10:32 AM   #19
u&k metal works
Tires=sold I still have 8lug wheels with beadlocks $400
