1986 Toyota 4Runner
Hate to sell, but some things have come up.
1986 Toyota 4runner frame is solid. body is a little used. heat works still has all emissions stuff and working A/C compressor in it. 22RE 5 spd Trans case has 1:1 high gear ratio and 4.7:1 low gear ratio T-G kit trans/tcase have been tucked twin sticked case tcase has a brake on it, not working front drive shaft is a square tube shaft rear is a solid shaft Front axle: SAS'd with an 85 axle has 4.10 gears and locker recently had knuckles serviced with TG kit flip kit high steer hydro assist steering diff covers armored Rear axle: 86 with 4.10s and detroit locker chevy 63" springs 36" TSL Swamper Bias with about 85% left on them rock sliders all around it has a cage over the back seat on the inside front seats have 4 point harnesses and reg. belts has a winch on it, but the negative cable going into the winch broke off runs great goes great have a good KY title in hand I m sure I forgot something asking $3500. send me a text at 859-393-7760 Last edited by NKYJEEPSTER; 02-10-2012 at 10:56 PM. |
still for sale, let s see what happens.
may trade for yota 4x4 that I can dd, 4 cyl. or maybe a 4x4 utility quad 400 or bigger.
Stupid question, but is it street legal?
I do not drive it on the street, but it has a clean title, headlights work(need new bulbs only high beams working now), brake lights work, not sure about the turn signals. It has been driven on the road, it would need some steering work and regear to daily drive it, so I always just trailered it. I plan to put 5.29s in it and fix steering. It needs either a new 4runner tie rod end for the pitman or upgrade to FJ80 pitman arm and tierod end. So yeah it could be driven on the road with a little work.
May trade for some guns and cash as well. |
I fixed the one ton tie rod end and that issue is cleared up. Would be interested in trading for a decent 4runner with a 22re/22r or maybe a decent utility quad something 350 or bigger.
