Old 06-08-2012, 12:31 AM   #1
mossyoaktj
mossyoaktj's Avatar
tj marker light question
so heres the problem im having. the running lights on the front of the tj arent working but the turns do. the rear running lights and turn work fine its just both of the front. tested the wirering and its all good for both running lights and marker lights, could it just be both front plugs need replaced.any ideas.
UNITED STATES MARINE
Old 06-08-2012, 01:47 AM   #2
Bulbs?
Old 06-08-2012, 04:07 AM   #3
mossyoaktj
mossyoaktj's Avatar
Bulbs?
put new bulbs in when i did the tj conversion, the problem was there before the conversion and yes they are dual filament bulbs.
Old 06-08-2012, 07:50 AM   #4
FluxIndustries
FluxIndustries's Avatar
I have had to replace the sockets on a few TJ's. It's wouldn't surprise me if the sockets are bad. They tend to hold a lot of crud.
Old 06-08-2012, 05:48 PM   #5
mossyoaktj
mossyoaktj's Avatar
i noticed that when i had the bulbs out. i just didnt see both front sockets going bad at once. or atleast notice it at once. any idea where the best place to order a set from.
Old 06-08-2012, 07:24 PM   #6
If they're anything like the XJ (and it sounds like they are: junk) you can get a suitable replacement (also junk, unfortunately) in the HELP section anywhere...
Old 06-08-2012, 09:34 PM   #7
tjrider
Just do what I did. Cut the fenders into flat fenders and delete the markers completely
Old 06-09-2012, 12:07 AM   #8
mossyoaktj
mossyoaktj's Avatar
thats what i did, im running hood line tube fenders and mounted jk turns into the cj location on the grill.
Old 06-09-2012, 12:08 AM   #9
mossyoaktj
mossyoaktj's Avatar
i think i need to go bigger on tires
Old 06-09-2012, 06:28 PM   #10
tjrider
I did the same thing, but I wired mine turn only. No more markers.
Old 06-10-2012, 10:22 PM   #11
FluxIndustries
There is tons of stuff out there to replace them with. The little plugs I have are pretty slick.
If I'm not mistaken they are on a series circuit, requiring both to be working. I know most I have replaced or messed with are a bit finicky.
Old 06-10-2012, 10:32 PM   #12
I dunno... That would only give each one six volts. I'm sure they're standard twelve volt bulbs...
Old 06-10-2012, 10:55 PM   #13
FluxIndustries
touche
Yep scratch that..
