Old 06-24-2012, 08:01 PM   #1
truk
truk's Avatar
warn winch no work!!
i have a warn winch that i stuck in mud last fall. i have used it 3 months ago. reinstalled the winch now it doest not work . i checked the wires to make sure they were on right and they were. so i checked the solnoids power to both small screws but no power out to cables. so im guessing solnoids. ?? so i was cleaning some of the wires off and 1 broke off so i need solnoids ! were is the best place to buy them. thanks matt
Old 06-24-2012, 08:14 PM   #2
I need to do this, too...
According to this: http://www.naxja.org/forum/showthread.php?t=1078763
The cheapest ones are here: http://www.dbelectrical.com/p-3579-4...6-smr6005.aspx
$71 for the fourpack.
If you find em cheaper, lemme know!
Old 06-24-2012, 08:33 PM   #3
jlynch
I have been down this road before with the solenoids. MAKE SURE when you buy these that they are 100% duty cycle!! I bought some cheap replacements that were not 100% duty cycle and when I used the winch for the first time the solenoid shorted out and I could not shut the winch off. By the time I got it to shut off it had burnt the winch motor up and kinked the winch cable real bad. Sometimes a cheap price is not good.
Old 06-25-2012, 08:47 AM   #4
Have you pulled the winch apart and made sure it was clean? If it got water/mud in the motor and then sat for 3 months it's not uncommone for it to stop working.
Old 06-25-2012, 10:56 AM   #5
coachholland
coachholland's Avatar
Those are discontinued and have been for a while and based on what they were sold for when available ($12 each), that's kind of high. The new part number is 72631 and I've got 15 of them on the shelf right now. I could do $72 on a set of four.
http://www.warnfactoryoutlet.com/sho...?edp_no=956552
Just another three linked stretched '95 YJ on 38s with a bunch of stuff scattered on the garage floor.
coachholland is offline   Reply With Quote
Old 06-25-2012, 12:20 PM   #6
I sometimes have problems with warn ropes... winches work great, ropes no good.
sorry, I have no input.
Old 06-25-2012, 12:26 PM   #7
Shoulda let tc drive... He wouldnt a needed a winch
Old 06-25-2012, 12:31 PM   #8
lol...
Old 06-25-2012, 02:43 PM   #9
truk
truk's Avatar
sorry coach if i would had known i would have got them from you. ordered from dbelectric last nite. well see if they work may and try to pull winch apart this week. thanks matt
Old 06-25-2012, 06:29 PM   #10
coachholland
No prob. If those universal ones don't work out, I've got the Warn brand ones for ya. :)
Old 06-27-2012, 09:14 PM   #11
truk
truk's Avatar
well it worked for about 1 minute! then it is stuck on ! hooked up solnoids and it ran in and out several times out about 2 ft each time then back in , then it stuck on going in unhooked battery and reversed terminals to run it out! now what! i guess ill do some checking make sure i wired it right. then send them back i guess. anty suggestions? matt
Old 06-28-2012, 11:54 AM   #12
coachholland
If they worked correctly before for several cycles, then you've got them hooked up right. Probably just poor quality knock offs. Get the real Warn ones for a buck more. ;)
Old 06-28-2012, 06:14 PM   #13
truk
truk's Avatar
after tapping on them with a wrench they work for a few times then stick always going in. so ive got it narrowed down to 1 solnoid. i have 1 old one left that didnt break when removing. so ill switch them and hope it all works for the zukimelt! i hope we dont need a winch while there, but then if i dont need a winch we arnt having fun!!!!!! ill be calling coach!!!!! thanks guys !!! matt
Old 06-28-2012, 07:22 PM   #14
"IF" you've just got one bad solenoid, you coud swap the four you have, so the bad one is in the "out" circuit. You'll use "Power In" a lot more than "Power Out."
But, I thought the thing used the solenoids in pairs, wired in series as a failsafe? Ie: if either solenoid opened, the winch would stop, even if the other stuck. No?
Could it be a problem with the controller? If you unplug it, does it continue to pull?
Dunno...
Old 06-28-2012, 09:32 PM   #15
truk
truk's Avatar
didnt try that but i will here in a few minutes.
