Old 04-15-2013, 11:23 AM   #1
Patrick45015
backlash
Sorry I bet this might have been covered but my dumb phone wont let me use search. I know how to set and check it. Did it tons in school but no real world experience. I am in specs but wonder what people found is best. I am towards the looser end. I am thinking of tightening it up, still in specs. Thoughts?
Old 04-15-2013, 01:57 PM   #2
Due to the differences in setup, might be helpful to share some details about the axle in question...
("tightening it up" for a "spanner style" axle like a 14bolt/9in is FAR different than a "shims behind pressed on bearings style" axle like most Dana axles for example...)
Also nice to know if it's a Daily Driver to trail only rig... Either way... "in spec" is really "in spec" so I would run with it... assuming good pattern.
Run a gear pattern with the marking compound, post up pic... then you should really get some interest...
My 2 pesos...
Old 04-15-2013, 02:59 PM   #3
Patrick45015
Its technically not even a diff its secondary drive in my wildcat trans. Its pretty much a miny diff. It uses shims. Not sure what caused the failure for sure so not sure their so called spec is good
Old 04-15-2013, 03:20 PM   #4
Ahh, well then I'm about useless... I have no idea about a wildcat trans... if the lubricant will stay contaminant free, I would think tighter would be better...
Curious, what was this failure you speak of?
Old 04-15-2013, 08:49 PM   #5
for regular ring and pinions, they loosen up so keep it on the tighter end of specs
