Old 06-25-2013, 08:30 PM   #1
Parts to build your own Driveshaft
I'm looking to build a new front driveshaft. I already have a 16 spline x 14" slip on my rig, but the guys at Cincinnati Driveline & Hydraulics only used an 2 1/2" splined female slip and now it wobbles like crazy. They suck! I need to find at least a 6" 16 spline female collar and some DOM tube to match it. The other end is just a 1350 joint. Anybody know of a place online or in town that would have these parts?
Old 06-26-2013, 12:46 AM   #2
fastford
Banned
Images: 13
Try this place 874-3680 used to be drivetrain specialist, can't remember the new name, they are off 747 by speedway
Old 06-26-2013, 12:46 AM   #3
I'm looking to build a new front driveshaft. I already have a 10 spline x 14" slip on my rig, but the guys at Cincinnati Driveline & Hydraulics only used an 1 1/2" splined female slip and now it wobbles like crazy. They suck! I need to find at least a 6" 10 spline female collar and some DOM tube to match it. The other end is just a 1350 joint. Anybody know of a place online or in town that would have these parts?
You can't get CDH to make good on their work?
No help with parts, sorry...
Old 06-26-2013, 11:10 AM   #4
I tried, they just looked at me like it was my fault.
They are good if you need a stock shaft. I had them build both shafts for me. I told them what I was doing with the truck, and it needed to be strong. They used .083 tube, yeah, that didn't last long... The front CV died in Harlan first trip. I sleeved them with sch. 40 pipe after I twisted them in half.
This is what I need. Name:  4002.jpg
The spline. Name:  longspline26.jpg
Old 06-26-2013, 04:47 PM   #5
kyrel69
you might try parts for a PTO shaft for a tractor. They are big and beefy looking but I would not want one if you plan on driving it on the road or going fast in Hi range.
Old 06-26-2013, 08:29 PM   #6
Correction. I was way off. It's an 1 5/8 - 16 spline shaft, not 10... Not sure where I got that at?? This might be easier to find...
Old 06-27-2013, 05:15 PM   #7
Looked for hours and can't find anything. Found plenty of 16 spline stuff, just not 1 5/8.
Old 06-27-2013, 06:12 PM   #8
fastford
Banned
Images: 13
Shot in the dark, but what about rumpke hydraulics over by you
Old 06-27-2013, 08:25 PM   #9
Driveshaftsuperstore.com may have what you are looking for. I believe they do.
Old 06-27-2013, 08:39 PM   #10
I looked at them several times yesterday. I didn't see a 16 spline coupler that was 1 5/8. They have one for the 10 spline though. I think I'm going a different route. I saw plenty of 9" slip setups. The most I could get my slip to move was 5". I guess 14" was a tad much...
Old 06-28-2013, 07:40 AM   #11
Jonesy
Jonesy's Avatar
Watching this. I'm in need of a long slip setup on one of my yotas but don't want to double the value of the truck with a new driveshaft. Cincy driveline was outrageously expensive when I got a quote from them.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 06-28-2013, 10:55 AM   #12
Yeah, they charged me $450 for the front shaft. Never again...
Old 06-28-2013, 12:39 PM   #13
Jonesy
Jonesy's Avatar
Found a place online, have heard they are reasonably priced but haven't looked into it much yet grobinc.com or something like that.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 06-28-2013, 11:38 PM   #14
I wonder if they sell to the general public? It might be hard to find a yoke to fit their spline.
Neapco sells a PTO setup for rock crawlers. It's similar to my setup.
http://www.drive-lines.com/parts1.php?pn=53-2415
http://www.drive-lines.com/parts1.php?pn=72-2231
I believe it's the same one http://driveshaftsuperstore.com is selling.
Old 08-27-2013, 02:04 PM   #15
Does anyone know off hand what trucks use 1350 joints in their stock front drive shafts? I want to get one from u pull for a temporary fix until I link my truck. Or does anyone have one they will sell cheap? Length doesn't matter, I can fix that.
Old 08-27-2013, 03:01 PM   #16
I think late 90s chev one ton trucks had 1350 rears... Could use those to build one
Old 08-27-2013, 09:57 PM   #17
You won't find any with slip yoke driveshafts though. I would try looking at later model Dodge or Ford trucks with the diesels as I believe they have 1350's, though not sure if they have flanges and CV's but might get you the parts.
Old 08-27-2013, 10:17 PM   #18
Jonesy
Jonesy's Avatar
Just an update on what I'm working on. Ordered some shaft and couplers from surplus center. 1 3/8" 21 spline. A 12" shaft and 2 couplings (2 1/4" long each) ran me right at $100 shipped to the door. Going to attempt to make a long slip shaft for one of my Toyotas this weekend.
Anyone have any tips for keeping everything fairly straight and true?
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 08-28-2013, 01:44 PM   #19
It's Power Clutch & Drive now. I called them yesterday to see if they can match a slip to my 16 spline shaft. I have to take it them and see if they have anything. If not, off to you pull...
I don't know if an 1 3/8 shaft would hold up in my rig. It would be nice if I could.
That's the hard part. I usually just roll it back and forth and eyeball it. I would never notice a vibration with my tires though.
Old 08-28-2013, 02:09 PM   #20
don't know if it will work for your stuff having not seen it but when I have lengthened or shortened some I use a piece of angle iron long enough to lay the pieces in and that will keep 2 sides straight and that has always worked for me.
Old 08-28-2013, 02:57 PM   #21
Drivetrain America sells every driveshaft part u could ever dream up...,call em they r easy to deal with Snd decent on price
Old 08-28-2013, 03:05 PM   #22
Diameter should be kept as small as possible for clearance issues such as rocks and crossmembers. 1/4" wall tubing at 1 3/8" diameter held up to a stout big block with no problems.
Old 08-29-2013, 07:44 AM   #23
I always used these from power clutch and drive. they usually have
them in stock.
the parts are made by Neapco,
the male # is 72-2231
female is # 53-2415
Old 08-29-2013, 07:45 AM   #24
had to weld my ends on
Old 08-29-2013, 06:07 PM   #25
kyrel69
them in stock.
female is # 53-2415
do you have the price you paid?
