Old 10-31-2015, 11:09 AM   #1
Led lights
Is there anyone around here that sells them or am I stuck going to eBay?
Old 10-31-2015, 12:18 PM   #2
4Mudders up on 32. At Grays Towing.
Old 10-31-2015, 12:42 PM
Old 10-31-2015, 03:13 PM   #3
I am looking for some headlight bulbs to go in my projector housings. I had hids but they caused all kinds of electrical meltdowns so I stuck some halogens in there. I'm not happy with the halogens and I can't go back to regular headlight housings because you have to cut out the headlight panel to make the projectors fit
Old 10-31-2015, 03:16 PM   #4
Do I just walk into grays towing?
Old 10-31-2015, 03:58 PM
Old 10-31-2015, 04:00 PM   #5
Yep. Or hit up Adam Fertig on facebook, in TriState Jeeps.
Old 10-31-2015, 04:16 PM
Old 10-31-2015, 04:28 PM
Old 10-31-2015, 04:58 PM   #6
These are the housings. I'm guessing it was China hid stuff. Housings ballasts and bulbs were 150. Unfortunately I did my hid research after I had issues. I found out it takes a lot to get diesels to get along with HIDs. They ended up frying my injector module.
Old 10-31-2015, 05:43 PM
Old 10-31-2015, 06:01 PM
Old 10-31-2015, 06:23 PM
Old 11-01-2015, 10:29 AM   #7
They were not tied into the factory system. Everything was separated but what I found out is the radio frequency The ballasts put out messes with the electronics. The ballast also pulls too much power on startup and the computer sees 0 volts. I tried running each light to a separate battery, both to one battery, both to the other battery, and both to the main lug on the fuse block. I heard it is a common diesel problem
Old 11-01-2015, 01:54 PM
Old 11-01-2015, 02:09 PM
Old 11-01-2015, 04:41 PM   #8
I don't know the specifics on the why's but powerstroke forums are full of this stuff
Old 11-01-2015, 05:18 PM
Old 11-04-2015, 10:55 PM   #9
Kind of. The hids were causing all kinds of goofy stuff. Once when I switched them on the throttle went wide open and stuck. Usually it killed the engine. Eventually the idm shorted. Maybe it was cheap hids but I don't want to deal with them anymore
Old 11-05-2015, 01:05 AM
Old 04-29-2016, 11:13 AM
