- Moderator - |
39.5 x 13.5 x15 Iroks on beadlocks
Time has come to get some new tread
4 tires that are pretty wore out, lots and lots of Rock Rash 15x8 wheels 32 bolt beadlock with 2.25 inch backspacing These tires will still get you around, just requires a little more wheel speed in the extreme trails $600.00 firm takes wheels and Tires Don't waste my time with low ball offers, I will just keep it all for less than $600.00
I still need to get those Boggers for you to try...
This makes me happy.
Well....what're going to be the replacements?!?! Coughredlabelscough
- Moderator - |
Well after doing research I found that the Reds work better on dry rock trail conditions, can't seem to find trails that match that, Treps are rated Higher for wet rock/ Mud conditions..Reds are a bit cheaper than Treps but have been reading horror stories about the Reds Sidewall, I'm pretty rough on equipment and can't get that outa my head. Also looks like the Waiting list is pretty long to get the Reds available to get om the rig.
- Moderator - |
If I'm gonna gonna spend $$ on new tires that have to last me years to come I'm gonna spend a little extra with no regrets and get stickys.
#10 | |
I guess one in how many years isn't bad.
Not mine...
Sticky's wear down very fast. Just FYI.
You got it" ![]() |
#14 | |
You got it" ![]() |
#15 |
You got it" ![]() |
#16 |
Crawford....get the treps and never look back!
#17 | |
Trep sidewall strength is not an issue: Any tire would have failed where I put the hole in the sidewall of that brand new Trep. The jeep landed with full weight and momentum into a sharp pointed rock right right into the sidewall on the downhill side on Little Jagger. I still have that tire on the rig several years after having the sidewall vulcanized. |
