Old 07-27-2010, 04:28 PM   #1
RuffedUpXJ
RuffedUpXJ's Avatar
Machine Shop Needed
I do maintence on my cousins' lawn mowers for their business and they recently let a walk-behind run low on oil. Its a Toro I believe and with a Kawaski engine. I was wondering if anyone knew of a machine around to rebore so I can put a larger piston it and hopefully get them going versus paying $1600 for a new crate engine from their dealer.
I would assume this is reasonable since its a 17 hp motor and I can imagine that they have a series of motors that use the same block/piston setup and I would believe they have over sized pistons for this matter.
Anyone know a machine shop in the hamilton/Fairfield/Mason aera that would bore it out for me?
Old 07-27-2010, 04:42 PM   #2
have you checked on an oversized piston yet because to cusom make something could get pricey. see whats available if you havent allready then i think someone will chime in with ideas(pater?)
Old 07-27-2010, 05:28 PM   #3
I could bore it if you give me the jug and the dimension it needs to be. Ask west chester or fairfield power equipment for the replacement goods and for ideas.
Old 07-27-2010, 05:53 PM   #4
If all else fails, Bubb or Mark wilson at Cresent springs hardware are the go to guys,
2460 Anderson Road
Crescent Springs, KY 41017-1402
(859) 341-0800
Old 07-27-2010, 06:38 PM   #5
It got ran out of oil and you think it needs a piston?
Hell , anytime I hurt something due to low oil PSI it was crank journals.
Old 07-27-2010, 07:40 PM   #6
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
i was thinkin the same while i was readin down the page, prob jus a crank turn and over size rod bearing
Old 07-27-2010, 07:53 PM   #7
RuffedUpXJ
RuffedUpXJ's Avatar
Well my cousins aren't the sharpest tools in the shed when it comes to mechanical things, I really don't know why they bought all this equipment for lawn care.
Anyways back to the topic, they brought the motor over in pieces and they spun a main bearing. So the crank is messed up and where the bearing sits in the block its obvisiously messed up. So I am trying to get a scematic of the motor, I think its a FH541V.
I think I might take it down to Fairfield Power and Equipment to have them take a look. I can get some pictures if anyone has experience with small motors.
Old 07-27-2010, 11:46 PM   #8
fordman00
fordman00's Avatar
you could try getting ahold of butler tech precison machining class. Teachers name is halcomb. i dont know what he'd charge you if anything.
Old 07-28-2010, 11:10 PM   #9
berrym2
berrym2's Avatar
http://www.j-thomas.com/
reasonable prices on replacement engines and parts. and quick shipping
berrym2 is offline   Reply With Quote
Old 07-29-2010, 12:47 PM   #10
muddinredneck513
muddinredneck513's Avatar
or try baker hardware out through millville on 129 like your goin to brookville
