Old 01-28-2011, 06:58 AM   #1
Exclamation yota axle question
will 91 or 88 rear axle fit under a sami, it is from IFS setup truck, believe to be 58" width.
Old 01-28-2011, 07:18 AM   #2
RuffedUpXJ
RuffedUpXJ's Avatar
The Tech. Section might be able to tell you. Sure it will everything fits.
Old 01-28-2011, 08:34 AM   #3
re-do your perches, get new wheels and roll.
Old 01-28-2011, 12:05 PM   #4
krawlin85toy
krawlin85toy's Avatar
Images: 76
its wider than the 79-85 by 3" you would be using spacers on front then.
a good rear axle for sammies are 79-85 unless you plan on doing a front and rear toy swap.hope this helps.
Old 01-28-2011, 02:50 PM   #5
Green Zuggy
Green Zuggy's Avatar
Images: 231
Instead of spacers you could also go with a Rock Assault Axle from Trail Gear to get the 3" wider front to match the IFS rear.
Jeff
Old 01-28-2011, 05:24 PM   #6
8UP
This. Not only that but the earlier years are cheaper, most Toyota guys prefer the later, wider rears.
Old 01-28-2011, 06:39 PM   #7
krawlin85toy
Images: 76
QUOTE=8UP;46698]This. Not only that but the earlier years are cheaper, most Toyota guys prefer the later, wider rears.[/QUOTE]
depends on what you are talking about!
Old 01-28-2011, 06:42 PM   #8
mike shelton
axles
i got a set of early axles with 33-10.50 sx tires, 350.00 for all. mike
