Old 08-29-2011, 04:15 PM   #1
bad gas
Our fuel station sold us some very dirty gas. I took the filters off the trucks and it looked like sand coming out. 4 F-250s were screwed up. Here is the kicker though. A chevy van with a 350 is still running fine. I was told the Fords atomize the fuel better and the chevy would run if there was a midget under the hood dumping fuel down the intake but wouldnt it have some issues????
Old 08-29-2011, 06:35 PM   #2
No, Chevy's rule!
Old 08-29-2011, 06:53 PM   #3
No, Chevy's rule!
Old 08-29-2011, 06:55 PM   #4
No, Chevy's rule!
Yea maybe. Or they are just designed to run on crappy gas.....
Old 08-29-2011, 06:59 PM   #5
I pee in my tank and my truck runs fine!
Old 08-29-2011, 07:43 PM   #6
ive seen what you eat so im not surprised
Old 08-29-2011, 07:44 PM   #7
So that is what your sticker means
Old 08-29-2011, 08:24 PM   #8
What sticker? :confused:
Old 08-29-2011, 11:33 PM   #9
Side window of your truck
Old 08-30-2011, 03:05 AM   #10
frankensteinxj
frankensteinxj's Avatar
No, Chevy's rule!
Here is your answer.
BYAAH!!!
Old 08-30-2011, 09:51 AM   #11
The fuel station should take care of all your problems for you (expense wise) in this situation. I would take the Chevrolet to a local shop, and have them test it for you. I'm sure that the pump will give out sooner due to the bad gas it's not made for going through it.
I would assume the diesel was mixed with gas or vice-versa. If that's the case then you're not the only one with issues from THEIR problem. We've fixed this problem for one of our customers before when it happened at speedway & they were very easy to deal with & get paid.
We pumped the (mixed) gas out of the trucks & put it in a big container in our shop. A couple of us got brave since they didn't want the gas back & tried running it. Friend's Honda fuel pump bit the dust the same day. My 97 chevy van ran fine for a week, then the pump & injectors (spider!) bit the dust soon after.
Old 08-30-2011, 03:49 PM   #12
Old 08-30-2011, 11:23 PM   #13
Unfortunately the station is denying any issues but I noticed today they had all their pumps blocked off. The other issue we are running into is noone can tell me who will check the quality of the gas. I found out today all the Fords went to the same pump. The Chevy went to a different set of pumps. Wouldnt it be the same tank though?
Old 08-30-2011, 11:27 PM   #14
Just guessin, maybe the same tank but a different filter feeding each pump?
Dunno...
Old 08-31-2011, 07:59 AM   #15
Some fueling stations have multiple tanks feeding different pumps.......ever pulled into a gas station and only some of the regular no-lead gas pumps were taped off?
There could be several different reasons for the Chevy still running okay. One is that the fuel came from a different tank. Two could be the fuel filter was able to catch the debris and not get clogged.
If you had what looked like visible sand in the filter that would still plug up the injectors on any half-way modern fuel injected setup.
Old 08-31-2011, 04:55 PM   #16
No sand was just what came to mind. I dropped the tank on the truck running the worst and cleaned what looked like sludge out of the bottom of the tank. Cleaned the pump pickup screen and changed the fuel filter again and it ran perfect all day.
They are still denying any issues with their gas. This is irritating
Old 08-31-2011, 06:03 PM   #17
That sucks! I would contact lawyer.
Old 09-02-2011, 06:05 PM   #18
cincygman
I used to put just about any thing in my chevy and it would run. just short of beer.............
Romans 7-8
