Old 12-31-2011, 09:07 AM   #1
tjrider
welding a winch plate?
So I picked up a smittybuilt plate for the tj. Problem is it sticks out way past my framerails. I'm not running a front swaybar so I have open real estate in front of the grille. About 3". Can I just slide the plate back on the frame and weld it on? I want the winch as tight as I can get against the grille
Old 12-31-2011, 09:16 AM   #2
Why not bolt it in place instead of welding.As long as it bolted to the frame you should be fine.
WHO-DEY
