Old 04-12-2012, 03:24 AM   #1
Question car issue
ok GF's 98 neon blew the timing belt and maybe the water pump..i read on line that these are interfence motors which means it more than likely bent the valves... one garage I talked to said about 1000 to fix it if it was the timing belt...
So would it be cheaper to swap engines? or try and fix this myself( swap out head and replace water pump)? of course never done it or have the ablity to do the engine swap?
when i took the cover off the right fender well I found the timing belt rapped up behind the harmonic balancer wheel and some plastic peices fell out...
engine only has 88k on it.
Old 04-12-2012, 08:46 AM
Old 04-12-2012, 09:07 AM   #2
Sell the parts that r good... Scrap rest of car... Go buy another car... And not a neon... Just my .02
Old 04-12-2012, 08:23 PM   #3
tinbeater
tinbeater's Avatar
If its a sohc it didnt bend the valves. The worst part about doing the timing belt is getting the crank pulley off, better have the right puller. If you decide to do it yourself be sure and replace the water pump and belt tensioner. Guys that work with me can ussually do the whole job in less than 3 hours.
I just did my daughters a few months ago and put new belts, battery, thermastat, flushed the cooling sytem, replaced the tensioner and water pump in around 5 hours. If you dont want to mess with it and are interested in selling it I may be interested in buying it.
Old 04-13-2012, 08:31 AM   #4
smack4130
like he said ive had good luck with just sticking a new belt and water pump on and trying it but if its a dohc is toast might check with autozone about renting the puller for the crank pully and giving it a go its nearly the same as your sammuri just line up the dots or arrows and go wih it
smack4130 is offline   Reply With Quote
Old 04-14-2012, 02:59 AM   #5
well it is the dohc, so it more than likely toast... who wants to do it for me? No time really to do it. work 2 jobs 16 hour days , 6 days a week... Come on day job m-f so I quit the night job...
do you see and issue???
Old 04-14-2012, 11:35 AM   #6
i can put you in touch with a couple good wrench turners...
Old 04-18-2012, 10:21 PM   #7
send me and email
1967fastback@gmail.com
how they are a good cheap price.. she still not sure what she wants to do yet..:confused:
