Old 10-10-2007, 09:33 AM   #1
Question ok, so WTF is this?
I finally drug the mystery axle that was left in my yard when I moved in around to the front of the garage (that fugger is heavy). I even took some photos of it. Can someone help me identify it???
It has an 8-lug bolt pattern & 8 little bolts in the hub. The (SUA) spring perches are angled to the side. The diff cover has 10 bolts in 2 different sizes.
Old 10-10-2007, 09:37 AM   #2
OLD MILITARY ROCKWELL AXLE? :confused:
Old 10-10-2007, 10:05 AM   #3
Smile
It looks like photos #8 & #9 on this page:
http://www.blackbirdscustomtrucks.com/index5.html
What does that mean it is???
Old 10-10-2007, 10:23 AM   #4
An old eaton rear axle maybe. Expensive and maybe more difficult to find parts on. I'll bet the ratio is low!
Old 10-10-2007, 10:24 AM   #5
scarface
I beat anorexia!
scarface's Avatar
hit it with the sand blaster and see whats inside
Old 10-10-2007, 11:36 AM   #6
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Looks to me like a 60's GM Eaton axle
Old 10-10-2007, 11:42 AM   #7
Yup looks like a eaton. Pretty strong but very hard to find parts for.
Old 10-10-2007, 12:27 PM   #8
eaton, worth about it's weight in scrap... unless you have the matching front.
Old 10-11-2007, 08:16 AM   #9
It's an old Eaton axle out of an 60-70's era Chevy/GM pickup that used the trailing arm style suspension.
They are generally known to be pretty stout and often come with 4.56 or 5.13 gears, and sometimes a Detroit. I've seen lots of guys running these in fullsize trucks with no issues. But as already mentioned it's getting pretty hard to find parts for.
Not quite sure what the "unless you have the matching front" comment means??? It should be a fairly common width and standard 8-lug pattern which matches just about any 8-lug front axle, not like it has a funky bolt pattern like some of the old military axles.
Old 10-11-2007, 02:59 PM   #10
kyrel69
so what are you going to do with the axle now that you know what it is?
It can come and join all my axle at my house lol
Old 10-11-2007, 03:02 PM   #11
thought it was a funky ratio.
Old 10-11-2007, 03:18 PM   #12
Unhappy
Not sure what I'l ldo with it, I want to clean it up & look inside & see if all is ok or not. It has been sitting outside for a few years, so all may not be well.
Old 12-23-2007, 09:57 AM
scotty85
This message has been deleted by scotty85.
Old 12-23-2007, 10:00 AM   #13
scotty85
build it,not buy it!
scotty85's Avatar
the track bar mount-looking thing and angled "perches" prolly mean it was froma coil-equipped c20. i wouldnt scrap it-it may well be worth something to someone with that era truck. 67-72 era trucks and parts are certainly getting harder to find.
what ever happened with this? did you open it up?
scotty
77 scout II truggy
84 chevy "home made crewcab"
scotty85 is offline   Reply With Quote
Old 01-09-2008, 04:03 PM   #14
Deranged89
Deranged89's Avatar
While Were On The Subject Of Mystery Axles Ive Got One For Yall. Rght Now Its On A Small Boat Trailer I Have. Its Only About 4' Wide At Most (and Shows No Signs Of Being Shortened), Has A Square Diff Housing, The Axle Shafts Are Threaded On The OUTER Ends With A Keyway And Use A Crown Nut And Cotter Pin To Hold The Hub On, 4lug, And 12" Rims. Aint Got No Pics Of It At The Moment But Can Take Some If Anyone Might Have A Guess.
REMEMBER WHEN GAS USED TO ONLY COST AN ARM AND A LEG???
Deranged89 is offline   Reply With Quote
Old 01-09-2008, 04:46 PM   #15
Bear Chow
Jeepless
Bear Chow's Avatar
Tractor axle
Old 01-09-2008, 11:15 PM   #16
Deranged89
Deranged89's Avatar
never thought of that, quite possible now that i think about it.
Old 01-13-2008, 11:55 AM   #17
Gunrunner
Gunrunner's Avatar
I know a guy that runs them (Eatons) in truck pulling, he said he tears up 14 bolts and the eaton just keeps digging. Let me know if you are going to dump it and I will ask what he will pay for one.
There are no stupid questions, but the world is full of inquisitive idiots.
Gunrunner is offline   Reply With Quote
