Old 06-29-2014, 08:07 PM   #1
Eps
I'm wanting to put power steering on my rzr. Any certain brand better that the others?
Here are some I found. Surly the factory unit is best, but also the most $$$. What about the others though?
http://www.superatv.com/Polaris-RZR-...1083C1037.aspx
http://www.wickedbilt.com/electra-st...steer-kit.html
http://www.polaris.com/en-us/rzr-sid...er/pid-2878522
Old 07-02-2014, 12:06 PM   #2
Nobody knows huh... Oh well, it was worth a shot.
Old 07-04-2014, 09:04 AM   #3
solar1
10
I installed super atv on mine. No complaints really. However it isn't speed sensitive like the factory power steering.
If you buy from super atv use this code at check out "RZRFORUMS". It will save you a bit of money. I think I ended up paying $585.
Old 07-04-2014, 10:45 AM   #4
Thanks, but I already bought it. Going to put it on today. I paid $520 for it. I can get used to the steering at higher speeds for saving $800. Speed sensitivity isn't worth $800 to me.
Old 07-04-2014, 10:17 PM   #5
solar1
10
Exactly. That is why I went with super atv.
Old 07-06-2014, 04:17 PM   #6
Are the kits you guy have plug and play?..I was under my dash today adding some rocker switches and noticed a couple capped off weatherpack type plugs in the harness. All I could think of was factory options my base XP doesn't have...power steering and winch ?
Old 07-06-2014, 10:45 PM   #7
Those could be for the factory equipment. All I had to do was run the power wires to the battery and 1 small wire to the key on power under the dash around the 12v plugin. Same with the winch.
Old 07-07-2014, 11:41 PM   #8
solar1
10
Those should be the keyed hot wires. I think there are two from my memory that are available.
Old 09-24-2014, 01:56 PM   #9
After using the Super ATV power steering for a while now, I can't complain. It seems to do the job. If anyone was questioning buying it, don't...
The one I bought. http://www.superatv.com/Polaris-RZR-...1083C1037.aspx
