propane
I put propane on my yota. starts and runs but when I let off gas it dies.Any suggestions?
#2 | |
Your wifes pimp!
Don't let off the gas......;)
Poor Bastard
Check your idle, check timing, check your power to the cylinoid. Propane is equal to 110 octane, you can advance the timing, but not to much or you will overheat. For the hell of it, do you have propoane & is it turned on?
sorry about spelling
I took this propane off another truck that I sold. It ran good on that toyota. Iam not the one that put it on the truck I sold so I didnt really Know what I was doing and no instructions just marked everything and swaped so i did not think I would have to ajust the idle.This truck has a header and flow master so I guess that could change the flow? And I not sure if I have the cylinoid pluged in ther right spot It was pluged into the green connector that was connected to the carb which has 3 spots in it and cylinoid only has 1 so I might not have it connected in the right spot? yes have propane turned on and just had tank filled.
