01-19-2008, 08:42 PM | #1 |
chevy motor/axle swap into a yj
Hello all, I've got a buddy that is putting a chevy 350 into a yj with some chevy axles.
What we do know He's got a '90 yj islander that is puke green/teal colored. He's got the motor, tranny, and xcase mounted in the jeep now. Looks like a dana 44 chevy front axle, and a rear 12 bolt. The 12 bolt has 3.07 gears, but haven't opened up the front yet. What we don't know for sure 1. Wondering if we can hack into the yj wiring harness to hook the engine up to the dash etc.., but facing the reality that we will probably have to get a painless kit and use that. 2. Probably going to need some custom driveshafts, but were wondering if anybody knows of any that may work, front or rear. 3. Whether or not we need to shorten the front axle. The rear axle will stay the same length. The front axle though, will need to be shortened by about 1.5-2 inches to center it on the frame and use the cast spring mount in the differential. 4. Whether we can use the same steering setup that is available. Yj box, with either yj tie rod or use the chevy tie rod (probably depends on whether or not we shorten the axle. This is about it for now, but realize there is still a lot of work to do. Plans are probably to be finished either this fall or next spring, not real sure. Just depends on what needs to be done, and what kind of time and money he has to put into it. thanks for all of your help. BiggDaddy |
01-19-2008, 11:01 PM | #2 |
You can hack into the stock harness but it will be a very long and tedious task where as the painless wiring will save u time. On the axle just relocate the perches and run a custom offset rims. Plan on having to resize the driveshafts. The painless wiring harness will be money well spent and the dash will be more functional. Good luck!
01-20-2008, 12:01 AM | #3 |
post up on miami valley 4 wheelers site . www.mv4w.com
I think it's "teach " on their site that can splice your harness up in an afternoon so it all works just like it did stock . |
01-20-2008, 01:09 PM | #4 | |
EFI AMC 360
I have spliced the YJ harness a few times to fit different motors. I spliced the one in Shawn B's YJ that Sarge is thinking about. What year of chevy motor do you have and do you have the chevy motor harness.
01-20-2008, 02:44 PM | #5 | |
If you shorten the front and dont do the rear it will look funny. Usually when truck axles are installed you need to move the front springs to the outside of the frame. Im sure someone here had a pic to post up if you dont know what Im talking about.
01-21-2008, 02:20 AM | #6 |
Sorry Mike , I couldn't remember who did Shawns off hand !
01-21-2008, 09:55 AM | #7 |
yes, don't shorten the axle, outboard the frame spring mount areas...
01-21-2008, 10:49 AM | #8 |
As already mentioned, it would be much simpler to move the front spring mounts then actually shortening the axle, especially for just a couple of inches. I believe there are companies out there that even make kits for this.
01-21-2008, 08:11 PM | #9 |
thanks guys
Hey thanks everybody. We'll take this advice and get on with the project. I'll try and snap a few pics next time I'm over so you can see how ugly this thing is. I'm sure I'll have some more questions for you sooner or later too. Thanks again.
BiggDaddy |
01-31-2008, 03:54 AM | #10 |
finally got some pics resized
Here are some pics. Took forever to figure out software to resize them.
01-31-2008, 04:02 AM | #11 |
he get that jeep off craiglist? i seen one on there a while back just like it with the sun lookin thing on the door!! if not it was its twin!!!
01-31-2008, 10:26 AM | #12 |
www.buckeyejeepers.com
He picked it up at a swap meet about 2 years ago. Sat in my barn until recently and hasn't been listed on craiglist.
01-31-2008, 10:33 AM | #13 |
Front doesn't really look like a 44. Can anyone verify if it is or isn't. Maybe a GM 10 bolt. Are these axles worth using?
01-31-2008, 10:38 AM | #14 |
Craigslist? no.
Nope. It's a package deal they had for a couple of years. I think '90 and'91. Picked up the whole Jeep for $500 and a couple of cj axles.
01-31-2008, 10:56 AM | #15 |
Appears to be light duty axles. What size and brand tire do you plan on running?
01-31-2008, 11:03 AM | #16 |
Not sure but I would guess 33s or 35s. Probably whatever we find for him cheap. I am going to suggest to him that we look for some different axles, especially running them behind a mild built 350.
01-31-2008, 11:38 AM | #17 |
Your wifes pimp!
Axles are 10 bolts the front will take 35's I would not go larger then 33's though casue the rear is a c-clip axle.
01-31-2008, 11:47 AM | #18 |
Buy my 60/70 combo and be done! I also have a 30 front and 35 rear with 4.10 ratio from a 94 wrangler. Make me an offer!
01-31-2008, 04:02 PM | #20 |
Looks like a 10-bolt front axle to me. But whether it's a D44 or 10-bolt shouldn't make any difference because they are basically identical in strength.
In my opinion that fact that the rear axle is a c-clip design is a moot point in regards to strength. The c-clip in no way makes the axle any weaker than if everything else was identical with the exception of the c-clips. Sure, if you break a shaft it can spit off the tire end, but so can a flanged (non c-clip) axle (I've seen two flanged D44 rear axles do this). But in any case they aren't exactly the epitome of beef in regards to axles, and the gearing sucks, but should hold up reasonably well under a light vehicle only running 33-35" tires. This also assuming they are in good condition, if the shafts and such have already been beat on hard for 20+ years then they would have a lot of fatigue life. |
02-01-2008, 12:06 PM | #21 |
my old rig ( now Hybrids ) was on 10 bolts and I beat the crap out of it , never had a problem with the rear and it was welded. Started breaking fronts only after welding it up , I was running 35" boggers and a mild 350.
Biggest mistake I made was going to a 14 bolt in the rear and still running 35's , it was worse then running 31's with the 10 bolts . " no clearance!!" I would run the 10 bolts and up to 35's for now. Get a couple trail spares and have fun. The 10 bolts are dirt cheap and easy to work on and easy to find in the scrap yards. |
02-01-2008, 12:44 PM | #22 | |
