Old 05-05-2009, 02:43 PM   #376
These shots look good, almost like it's ready to go somewhere. Paint work done...
Switch panel arrived, from 12voltguy of course. It is a pretty thing. the backside looks like i might need to attend a year of electricians school to figure it out... Lets hope it's easier than it looks... very intimidating.
Got rear limit straps done. Had to shave the top of one side of my link mounts for the straps to work. when tightened it was puting the webbing right against metal. wouldnt last long that way. Still have to do the fronts.
Got my list made for all my steering hose parts, just need to get it all. Gonna use reusable fittings, for ease of trail repair if necessary.
So, steering, trans lines, wiring, exhaust, propane feed... that might be it.
Old 05-05-2009, 03:23 PM   #377
I like the resetable breakers and the indicator lights on the switch panel.
Old 05-05-2009, 03:27 PM   #378
seabass does good work.
Old 05-05-2009, 05:17 PM   #379
bet that was cheap
lets see the back
Old 05-05-2009, 09:32 PM   #380
redcj3a
redcj3a's Avatar
Looks to me like Carwash does also.
Old 05-05-2009, 09:37 PM   #381
tinbeater
tinbeater's Avatar
Lookin good Wash.
Old 05-06-2009, 01:40 AM   #382
you guys are too kind.
I will get a shot of the back for ya rob.
Old 05-06-2009, 08:14 AM   #383
Stang849
Stinkin Bastige
Stang849's Avatar
Images: 236
Looking good Carwash!!!!.... what will only be another year or so before its on the trail.... JFWY
Friendship is like peeing your pants, everyone can see it,
But only you can feel the true warmth.
Old 05-06-2009, 08:30 AM   #384
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Been following the build, Looks awesome. Needs a nice Buckeyes logo on the side!:) (Hope that doesn't offend you)
1994 YJ, 4.0, 5 speed.
Old 05-08-2009, 03:50 PM   #385
awe inspiring. id like to live in your shop.
Old 05-08-2009, 04:32 PM   #386
I suggested the Buckeyes theme a year or so back... Mike was less than enthused...
I have to say if I had the ability and the coin this is the exact rig I would build. Big diffs, big motor, big Boggers and low C.O.G.... once again , nice job Mike.
Old 05-08-2009, 05:14 PM   #387
Ha, your shop is nicer than mine!! what are you even talking about?!
Yeah, I'm not a college football fan, and if i was, i would make it Crimson Tide themed anyway, everybody and their brother is an Ohio State fan. Damn near as bad as these retarded UK fans we have down here...
Can't it just be red and gray?
Old 05-08-2009, 05:35 PM   #388
JET455
Your wifes pimp!
JET455's Avatar
Didn't you mean Red and GAY!!!???
Old 05-22-2009, 01:27 AM   #389
Cut the dash out today for the switch panel... stressful, as there is about an asshair of room for error. The switches and crap on the backside go damn near all the way to the edge. So i had to cut a hole, yet somehow still leave some meat on the dash for the holes to hold the damn thing in. Measure 90 times, cut 90 times... a little at a time.
Anyways, its in, and looks mighty fine i might add, with the rest of my dash goodies..
Got the front towers cut for limit straps as well. Buttoning some more panels down with the final hardware, must say the stainless button head allens are sweet. Makes the hex heads i had on there look awful.
I have spent the last week sourcing fittings for my hydraulic steering hoses, it has been an absolute nightmare. Any of you fitting gurus out there... find me a 5/8 oring to -6 AN fitting... The only 5/8 i can find is that british standard ****, and its 14 TPI, that don't work. This is standard 5/8 fine thread... odd bird. Parker hose guy was baffled...
Anyways... coming along. Slow, but coming.
Old 05-22-2009, 06:46 AM   #390
Here is where I found my fittings.
https://www.surpluscenter.com/sort.a...c&keyword=HFJO
Old 05-22-2009, 10:59 AM   #391
still, no 5/8 oring to -6AN JIC there.
Old 05-22-2009, 11:09 AM   #392
Bear Chow
Jeepless
Bear Chow's Avatar
Looks great, you might just make it EJS 2010.
Old 05-22-2009, 11:33 AM   #393
Need one custom machined? Tried aeroquip off of 747 and port union in west chester ohio?
Old 05-22-2009, 11:40 AM   #394
i have finally sourced everything i need. I just adapted it up to a -8 from the -6. 5/8 oring doesnt seem to exist anywhere.
Old 05-22-2009, 11:41 AM   #395
yeah, shame i wont be able to afford to go...
Old 05-23-2009, 10:31 AM   #396
Nuts's Avatar
Looks awsome! and I'm glad I'm not the only one taking forever to finish their buggy lol
Old 05-23-2009, 12:41 PM   #397
mine has gone beyond taking forever... it's down right ridiculous.
Old 07-21-2009, 10:32 AM   #398
ok... trying to button this thing down. for those of you that haven't seen my other thread, i'm having some propane delivery issues i believe, can't get it to run well, idle, etc.
So, first thing on the list was to get my cooling set up well, so that i can keep the motor and evaporator cool enough to mess with it long enough to try and tune it.
If you recall, i was very worried about my top radiator hose and it clearing my alt pulley. Last night i spent about an hour and a half at the local AZ, with some bent coat hangers, trying to source some hoses for my top and bottom. I was successful, and the **** looks like it was made for the rig... so that's good.
Got the throttle linkage and accelerator pedal installed, rear lights wired and loomed to the front, all the rest of wiring parts are ordered from seabass, even filled the damn diffs!
Goal is to make it to the benefit on August 8th, doable i think. But it's me we are talking about here... so don't count on it.
Need to get propane squared away, bleed steering, bleed brakes, finish wiring, exhaust. Cross your fingers.
Old 07-21-2009, 03:48 PM   #399
Nuts's Avatar
Where is the other thread with the propane problem?or whats the problem?
Old 07-21-2009, 04:14 PM   #400
ah that thread is on pirate...
http://www.pirate4x4.com/forum/showthread.php?t=804097
are you a propane guru? if so, please come over.
