Old 07-08-2009, 12:29 PM   #1
frankensteinxj
frankensteinxj's Avatar
Running 33s with 3.55 gear
Has anyone ran 33s with a 3.55 gear. I drive my jeep on the road and on the trails and i need some advice. Im not sure if i have all the money to gear it out at the time. So Im just lookin for a second opinion
BYAAH!!!
Old 07-08-2009, 12:31 PM   #2
I did it.
It sucked.
I survived.
Old 07-08-2009, 01:14 PM   #3
Details on the Jeep (XJ, YJ, 4.0L, auto, 5-speed)?
A lot of "Jeeps" came with 3.07/3.08 gears stock, so 33's with 3.55 isn't a whole lot worse than the 3.07 and stock tire setup.
Like said above, it's not the optimum setup by any means but you can get by with it.
Old 07-08-2009, 01:22 PM   #4
NKYJEEPSTER
NKYJEEPSTER's Avatar
I had 33 s on my cj with 2.73 gears it ran just slower.
Old 07-08-2009, 01:31 PM   #5
I have 33s with 3.08 in my TJ and rarely see 5th gear...couldn't get out of it's own way if it had to.
Old 07-08-2009, 01:39 PM   #6
Well, username "FrankensteinXJ," so I assumed that...
And XJ's are pretty predictable: four-poppers got 410s, sticks got 307s, and 4.0 autos were 355s.
So I'm sure that's what he's got...
Old 07-08-2009, 01:53 PM   #7
4.10's would be perfect! Lets see a pic of the vehicle we are talking about.
Old 07-08-2009, 04:13 PM   #8
Twisted4x4
Guest
Posts: n/a
gears
ive got stock 4.10's in my 89 ford ranger with 35's. does great off road, but slow on the take off on the streets. ive also ran 28's and 30's before too and did excelent off road. had much better wheel spin with the smaller tires but still gets it good with 35's. you dont by chance happen to have a set of used 33's with decent tread layin around you wanna get rid of do you?? im in need of new tires.
Jon
Old 07-08-2009, 04:20 PM   #9
frankensteinxj
Its an automatic 4.0 litre. Thanks for the input, I think ill stick with the 3.55 for now because its expensive as s*** to buy the ring and pinion and pay someone to put them in haha. So maybe when im not laid off ill find the money to do it, but i think ill deal with it for now. Thank you all
BYAAH!!!
Old 07-08-2009, 07:10 PM   #10
I ran 32's on 3.55's for two years on my 87 xj 4.0 auto.. It wasn't to bad..
Mainly slowed you down on the hills at hwy speeds.
Old 07-09-2009, 04:43 PM   #11
Been doing it for years, sucked much worse when I had a tired out motor, but with a decent motor & tranny it aint too bad. My recommendation though is to get a set of cheap ass ATs for daily driving & save your mud tires for wheeling. I've burnt off some nice tread using my XJ as a daily driver in the past, now it's just a trailer queen though. Another suggestion is to add a trans cooler, as big tires on stock gears is about the same as towing a trailer all the time, leading to a hot trans, leading to trans failure eventually.
I have a complete 4.10 geared XJ for sale for $250 for you to regear your axles with, then sell the rest for parts/scrap. May drop a little on the price or deliver it if you're really interested in it, lol.
Old 07-14-2009, 09:50 PM   #12
I have run the 3.54 gears with 33 inch tires on my CJ for 30 years. Since you have a slush box you should be fine. Do they make lower gears for your transfer case???? I have a case with the Tera Low gears in it, but it is still sitting in the garage. The only problem I have is when I'm pulling my Polaris, but she gets it done.
Old 07-14-2009, 09:54 PM   #13
are you talking about in an XJ? need to know what tranny also, there's too many other gearing variables to work in with different trannies for anyone to be able to properly answer your question.
