Old 07-29-2009, 11:37 PM   #1
Nuts's Avatar
What ring and pinion?
How do i figure out what gear is in my axle? Incase someone knows off the top of their head, its a 14 bolt full floater in a 1988 3/4 ton,2wd suburban with a 454 and Th400.
Old 07-29-2009, 11:43 PM   #2
well if this is an option jack up the burb and rotate the tires one turn and count how many times the yoke on the pinion turns and that will get you close. if you have a grease pencil to make a spot on each it makes it easier also.
Old 07-29-2009, 11:54 PM   #3
Nuts's Avatar
Yeah, I was hoping to avoid that and that there would be a number stamped somewhere I haven't found yet.
Old 07-30-2009, 12:01 AM   #4
well it could still have the sticker on the inside of the glove box that has all your option codes on it but i think by then they were all codes and you would still have to dissect the numbers unless some chevy geek has them all memorized
Old 07-30-2009, 12:10 AM   #5
I have my bet on 3.73.
Old 07-30-2009, 12:32 AM   #6
Trigger
There should be a series of numbers on the ring gear. If you get the numbers, I can tell you the ratio. 41 10 is 4.10 41 11 is 3.73, etc.
Old 07-30-2009, 02:04 AM   #7
u can get it from the code in the bottom of the inside of the glove box
look for the one that starts with g
gt4=3.43
gt5=4.10
gu4=3.08
gu5=3.23
gu6=3.42
1 starts with h
hc4=4.56
g80 means its a limited slip or posietractoion
Old 07-30-2009, 06:59 AM   #8
Nuts's Avatar
gt4=3.43
gt5=4.10
gu4=3.08
gu5=3.23
gu6=3.42
1 starts with h
hc4=4.56
Thanks man! Its a GT5 so I have what I was hoping for.
Old 07-30-2009, 09:57 AM   #9
Just remember that the code in the glovebox was what it came with from the factory 20+ years ago. Probably a good chance the axle and gears are still original, but unless you are confident of the history of the truck there is always a chance it was swapped out at some point in it's life. The only 100% sure way is to pull the cover and check the numbers stamped on the ring gear.
