A/C compressor elimanation
Does anybody know of a bracket/idler pulley to install in place of the a/c compressor on a Jeep 4.0? I did a search on Pirate,but not much help.
Thanks for the reply,but.......I don't want to add another alternator,just do away with the a/c compressor.
Get a smaller belt and play with the routing. Use a cut belt for measuring to get the length right.
Youdont realize how nice onboard air is until you have it. Why not try that?
91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon. Last edited by itbrokeagain; 10-12-2009 at 09:21 AM. |
#6 | |
http://www.jeepforum.com/forum/f11/my-oba-529670/
there is a pully that came on some MJs that replaces the AC pully.
I know I had one with it a couple years ago, but may be rare to find in a junkyard. |
Thanks for all the ideas,on board air can be a great add on.Several guys I wheel with have it on their rigs.Seems like they use the older York style compressor for oil reasons.For now I think I will go with Truggy's idea and reroute the belt and keep everything turning the right direction.I was just hoping to find a direct bolt in idler and use the same belt.Surely not all 4.0 jeeps had a/c.Thanks again for all the replies.
You could always make a mount for your Alt. where the AC comp is and then your alternator will be farther out of the water and dirt. but I am not sure if an idler pulley there or up top will be easier.
a/c delete
Found a thread on Pirate pertaining to moving the alternator to the a/c location,and another one pertaining to a/c delete.Both threads are in the Jeep/Cherokee section on page 17.The threads also have good pics.Sounds like a good idea to move the alternator up and away from the water and dirt.
yes, it is a good idea, or else get a front skid plate, or you'll be replacing the alt every couple trips out when you get in the deep stuff.
#12 | |
Been there, done that, got the mud in my eye to prove it... Robert
#13 |
I understand the alternator mount bracket from a 2.5 (Four banger) will bolt up in place of the a/c mount bracket on the 4.0. Then you just move your existing alt to the top bracket. Might shoot Commanchedude a Pm he done this mod a few years ago..
Good Luck Nick
