Old 10-23-2009, 05:24 PM   #5
i had the missfortune of that same problem and when i tore it down all the way i found a peice of rust scale that i guess i pushed into the seal when installing the axle. my suggestion would be to pullthat axle and let some fluid run out to kind of flush it out and see what you get. with the metal ramps on the seals there pretty tough to damage. good luck
My seals did not have no "metal ramps". I just ordered a Speedi Sleeve from Napa. I hope to pull the axle shaft out and find a groove in it.:confused:
